Most common tools to work on 928?
Ok, at the expense of getting flamed, I have read the Frequently Asked Questions and have used the "search" function, but cannot find a thread specific to 928 tools. So, what are the most common tools required to be a do-it-yourselfer Shark tuner? Taking into account: Top End Refresh jobs, timing belts, oil changes, tune-ups, and beyond.
Team Owner
a few special tools come to mind
1/2 in drive airgun
set of 1/2in drive impact sockets
1/2 in drive torque wrench.
Coil Spring compressors for shock changeout
Mapp gas torch
CO2 fire extinguisher
a 22,24, 27, 30 and 32 MM wrench set,
good for the cooler lines on the radiator and the block, and the tie rods, and oil temp spring housing, used on the cam pulley nut.
A short and deep 27mm 6 point socket for the crank bolt. ( impact sockets)
4,5,6, 8,10 mm triple square socket drivers for various bolts .
10mm1/4 in drive universal socket for oil pan bolts
8mm 1/4 in drive universal socket.
13,15,17,19mm 3/8 drive universal sockets
6,8,10,13,15,17,19,MM gear wrench set
3,4,5,6,8,10,mm allen sockets 3/8 drive.
thin wall socket for the spark plugs.
set of long handle needle nose pliers, these can be bought at HF in a set
and curved nose long handle pliers these can be bought at HF in a set
bent nose long handle pliers these can be bought at HF in a set
flywheel lock tool 2 different versions for early and late model.
Kempf tool for timing belt adjustments..
........... this is a start
1/2 in drive airgun
Mapp gas torch
Thank you, I am compiling a list for Christmas. Daddy wants new tools. ![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
Probably a good thread to have going, anyway, if it hasn't already been covered somewhere else.
Vegas, Baby!
![](https://rennlist.com/forums/images/ranks/veteran_navy.png)
![](https://rennlist.com/forums/images/ranks/veteran_marine_corp.png)
Unlimited VISA card, it's the ultimate tool, and it fits everything.
Useful to have a wrench for adjusting the suspenders and the special tool for the internally adjustable koni's if you have them fitted.
You also need a dial gauge kit, a vacuum pump kit [Silverline] and a compression tester is useful not to mention a pressure gauge for the fuel rail [only for diagnostic purposes!].
For the ST2, besides the kit itself you need a wideband O2 kit [I use the Innovate kit] and a netbook type laptop. you also need a torx socket set or whatever it is called to undo the little fasteners on the LH/EZ units when you change over the memory modules to PEMS.
Beyond that you are into fancy factory tools/pullers for major engine work. It would be nice to have a lift, an engine hoist and an engine stand but....
You can do the timing belt with the tools Mr Merlin has listed
Regards
Fred
Regards
Fred
Get a telescoping mirror - it will prove to be invaluable. When removing the rear shift coupler above the torque tube - it was worth every cent I paid for it. BTW - they're cheap, I think I paid $5 at a local parts store.
Get one that has a mirror that is big enough you can see with. I have another one which is a 1 inch diameter mirror that is only good for looking at your back teeth..
Multimeter for electrical troubleshooting.
TIME
