Most common tools to work on 928?
Oh, and a boroscope.
Old laptop with WiFI connection in the garage...and on it have the online manuals and Andrews spreadsheet for tq values or similar.
An understanding wife will help also.
Bolt ease-out/extractor (for stripped bolts--like the engine coolant drain plugs)
Fluid transfer pump (to refill tranny)
Brake bleeder (Motive comes to mind...)
The PVC cap to tap on the front main seal.
Oh, and circlip pliers!
Rennlist sub
60Nm, 200Nm torque wrench
As well as magnet on stick mentioned, one of those grabber claws on bendy shaft (handy for a console bolt that lives behind glovebox)
Loooong screwdriver for MAF clamp, alternatively 7mm wrench
Crow's foot wrench for PAS pump banjos
Channel lock pliers to remove tank sender nut
JDS Spanner
Mity Vac
JDS Spanner
Mity Vac
1 Post
Hi ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I have a full set of Snap-On tools, but this one has been used far more than any other, for electrical problems > http://www.ebay.co.uk/itm/SNAP-ON-BL...item1c210beaa4
Apologies for the Ebay link but only picture/description I can find at the moment (no affiliation)
Its a BRILLIANT tool.....called a power probe....
All the best Brett
All the best Brett
I have more in tools purchased since my second 928 than I paid for it. I have more in goop, sprays, dips, antisieze, loctite, than all the tools I had previous to it.
For all your tool addiction needs try, http://www.garagejournal.com/forum/forumdisplay.php?f=4 Second most expensive forum I've ever visited.
Current top of my shopping list, Double box end metric flex ratcheting deep spline long pattern wrenches.
O-ring pick set, contact cleaner, 3/8" pneumatic ratchet wrench, die grinder/dremmel tool, a flashlight you can hold between your teeth (do this only when alone) - I recommend Streamlight, and an LED rechargeable shoplight.
- Tow Trailer
- Laptop
- Rennlist
- 928 Owner's CLub
- Printer
- Cell phone
- 928 International
- Mastercard
- Lug wrench
- Jack
- 10mm (oil pan size) wrench and socket
- Screwdrivers
- All the other tools I have are about in equal use
