Uneven stance
You have personally verified this, yes?
Correction not required.
Are you saying the anti-sway bar can only be disconnected if the a 928 has an aftermarket adjustable drop links?
Colin, you and Danny obviously know way more than I about this kind of stuff so I will just bow out of this discussion.
Correction not required.Are you saying the anti-sway bar can only be disconnected if the a 928 has an aftermarket adjustable drop links?
With aftermarket adjustable drop links you disconnect them and then zero them before connecting so there is no preload.
If you don't have adjustables then leave them connected as you want to work with their preload.
