24lb injectors in a S4?
If you change from 19lb to 24lb injectors on a stock car, you must do tuning as well otherwise the car will run rich in open loop mode (cold start and WOT). It will also be more rich during cranking. So, don't expect to just drop them in and have them work exactly like the old ones. And 55psi is 3.5 bar ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Sharktuner makes this easy (and Malcom has access to one) but you are absolutely right, it needs to be mentioned in bold print:
If you change injector size, tuning is required!
Good catch!
(And while we are fixing things, 55psi is actually 3.8 bar
To add further clarity the car is a unmolested very stock 87 S4 with no provision for tuning.
Colins sharktuner is also my sharktuner (and several others).....coop buy from several years back.
I've been running 24lb injectors since I took off the rear turbo ages ago.... Stock brains. The car runs fine even at start up and at WOT.. but you do add more fuel at WOT....you can see the richness on the tail pipe. The actual fuel economy (not the digital gauge readout, it's optimistic) isn't any different from what it was previously.
Plans are to eventually put some pems in and sharktune...
Side note...I do have some issues currently with poor running as it transitions from open loop to closed loop...checked a bunch of stuff...next is the O2 sensor... I figure it's 6 or so years old..and perhaps the excess fuel has finally done it in?...
The LH will try to correct the excess fuel in the light/mid-range areas of the map. It does that by watching the factory O2 sensor and reducing fuel as needed, to maintain a stoichiometric mixture (14.7:1). You've got about 20% too much fuel and the range of the O2-adjust is around 20%, so it is OK... just.
Good plan, let me know how I can help. Installing PEM's and a quick tune will pick up some significant horsepower.
Cheers,
Snizinskas (06-12-2024)
THe change up to 24lb will cause a slight increase in fueling outside of closed loop running , the ecu in closed loop will try to attain lambda 1 if it is within the trims calibration to attain and reach this value , as the injector is only a glorified relay, the opening times a predetermined by the ecu . if you have a larger orifice to pass the fuel with same calibration via the ecu , then it is logical that more fuel will pass .
The digital dash takes it metreage of fuel used via the injector circuit , which is the pulse width applied to the injector circuit , therefore your economy will be slightly altered , as the dash is calibrated for the 19lb units .
Keep in mind that the stock system (up to 60 psi) is specified to run at a higher fuel pressure , than injector manufacturers specified their injection pressure (43 psi ) the stock system with the 19 lb is marginal anyway, I guess in this way they where able to ease some production costing .
My own car with the higher output engine has 30 lb fitted as it easily overwhelmed the stock setup .
All you need is for someone with a SharkTuner to load a stock S4 map, change the injector size to 24# and save that modified bin file as a 32k size file. Blow a 27C256 EPROM and fit it to the customer car.
No tuning required on customer car. I can email you the bin file if you know someone with an EPROM programmer and a blank 27C256 EPROM.
Former Vendor
Former Vendor
However, as Jim pointed out....the "Ford 19 pound" (ecconomical) injectors and the original "Porsche 19 pound injectors" (very expensive) have different flow rates, at 3.8 bar...so presumably if someone used a "Ford 19 pound injector" (which most people use, because of the price difference) they would benefit from Sharktuning, even with this slight change. (Since the stock 928 injection is set up to be extrememly rich at WOT, an increase in flow will only make it richer.)
Former Vendor
You are welcome.
What I failed to mention is that depending on how old your "stock" injectors are and how well they function, you might benefit from a new set injectors, regardless of how many pounds per hour they flow.
If you more than about 80,000 miles on your stock injectors, a new set of "Ford 19 pound injectors" is almost always going to "help". Combined with the slightly better flow rate and the 4 hole design, these injectors will "carry" a 928 engine to about 360 rwhp (with an automatic.)
