928 Forum 1978-1995
Sponsored by: 928 Specialists
Just Peachy OB project
Old 02-07-2013, 11:20 AM
  #301
xschop
xschop's Avatar
After the Beer, Tacos, and Hot Sauce a 17 fan minimum is in order at Dinsdale's Garage.
Old 02-07-2013, 12:40 PM
  #302
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,521 Likes on 1,420 Posts
Bruce Lee says he who throws dirt lose a lot of ground.
what fuel delivery system will the new engine require?
can you use the stock Bosch pump?
Old 02-07-2013, 01:26 PM
  #303
77tony
77tony's Avatar
Constant 60psi required. IIRC, Bosch pump off of 79 should handle it. T
Old 02-07-2013, 01:27 PM
  #304
Dinsdale Piranha
Dinsdale Piranha's Avatar
The venerable Bosch 044 will be providing those services.
Old 02-07-2013, 02:02 PM
  #305
Mrmerlin
Team Owner
Mrmerlin's Avatar
Where exactly do I have to go to get my prizes?
Dinsdale do you have a first name or is that how you roll with Dinsdale?
Cool so you dont have to mess with reworking fuel systems.
Your project looks great and the level of workmanship also top notch.
Old 02-07-2013, 03:20 PM
  #306
77tony
77tony's Avatar
Replies in blue: Where exactly do I have to go to get my prizes? Boilerplate contest rules apply-you must be present (Spring Fling, Apr 19-21st) to recieve your prizes (posts 286 & 292)
Dinsdale do you have a first name or is that how you roll with Dinsdale? Will answer to Dinsdale, Mr Piranha or if Corona's are present call him el conquistador
Cool so you dont have to mess with reworking fuel systems. Correct
Your project looks great and the level of workmanship also top notch. Thank you Stan, I'll pass that along to Dinsdale
Old 02-08-2013, 08:02 PM
  #307
77tony
77tony's Avatar
Dinsdale tracked down some nice big cadmium plated motor mount bolts. Steering rack & motor in. Rear tow hooks modeled by Dinsdale & your truly. T
Old 02-09-2013, 03:27 AM
  #308
Mrmerlin
Team Owner
Mrmerlin's Avatar
towhooksindeyez, yous guys need to drinks some Coronas
Nice paint job on the Jub Jub cone hat
Old 02-09-2013, 10:10 AM
  #309
Chuck Schreiber
Chuck Schreiber's Avatar
Keep the pics coming Tony!
BTW, those calipers came out great!!
Old 02-09-2013, 11:21 AM
  #310
xschop
xschop's Avatar
Looking good.....and the car too. What is the bottom pan to top X-member clearance?
Also interested what the intake to strut brace clearance when you get there. Looks like it's another Dinsdale masterpiece in the making.
Old 02-09-2013, 11:27 AM
  #311
Don Carter
Don Carter's Avatar
Stan, look closely at post 242.
Old 02-09-2013, 11:49 AM
  #312
77tony
77tony's Avatar
towhooksindeyez, yous guys need to drinks some Coronas OK
Dinsdale painted the script freehand.
Old 02-09-2013, 11:52 AM
  #313
77tony
77tony's Avatar
Originally Posted by xschop
Looking good.....and the car too Thanks Rob. What is the bottom pan to top X-member clearance? Mon ?
Also interested what the intake to strut brace clearance when you get there. We installed the strut brace yesterday & it just clears. Looks like it's another Dinsdale masterpiece in the making.
Yes
Old 02-09-2013, 05:26 PM
  #314
xschop
xschop's Avatar
I made my mounts drop the engine another 1/2". Need more C02 for the welder.
Old 02-09-2013, 08:07 PM
  #315
77tony
77tony's Avatar
Rob, Did you take in account the motor mounts might sag a little over time?. Liquid nails might be your solutionT
Quick Reply: Just Peachy OB project
