You're in good hands with Dinsdale, he knows what it'll take to get the Auto trans swapped in. If you are going to run the GM auto trans and 928 engine, you might as well interface the GM PCM to the 928 as well.
Who's going 1st with the 6L80 your 78 or the 94 ? T
What are the GM Part#'s on those headers? Someone wanting to do the LS swap in Cali would have to have them installed.
GM P/N for the LS376/525 motor is: 19259233 Pictured above are the OEM exhaust manifolds that the motor came with. Why doesn't your friend in Cali just go ahead and buy the Sanderson blockhugger headers ? T
I thought cars 25+ years old are exempt from smog in Cali. Can order the Sanderson's in black & add a cat or two? If he really wants the OEM manifolds maybe I'll sell him mine. What size LS motor is he running? T
Not for an engine swapped car. The engine has to have it's factory smog crap hooked up.
IIRC, Eric said the 2010 Camaro manifolds clear everything too.
GM didn't want to miss anyone. E-Rod crate motors are taylor made for the Cali guys. T
