Can anyone explain....(headlight wiring)
The motor has switches inside.Yours is not telling the relay to park in the UP position and that it is OK to turn on the illumination. The lights only come on when fully up. The headlight motor is mounted with three bolts in slotted holes so you can adjust the motor slightly. Sometimes that will alllow the switch to make contact.
Joel
Electron Wrangler
If it won't come back down but otherwise works OK you may have a busted diode in the headlight motor parking track mechanism, or a wiper that doesn't make contact. You will need to remove the motor for these - so try adjusting first (but I don't think that is your issue here). Start dissembling the motor top until you can see the track, check for wiper connections to the track and test the diodes with a DMM. Similar evaluation for the previous post.
Alan
Alan
