928 Forum 1978-1995
Sponsored by: 928 Specialists
Bosch Long Haul Alternators - anyone tried one?
Old 11-05-2011, 07:00 PM
Alan
Electron Wrangler
Alan's Avatar
Default Bosch Long Haul Alternators - anyone tried one?
I found something possibly interesting... these alternators (with J180 mounts) have interesting design goals: 160A spec with high temperature performance with good idle generating power at down to 1500-1800 alt RPM (80A) and rotation to 18,000 alt rpm allowing up to at least 2.7:1 pulley ratios.
I haven't tried one and haven't even been able to compare case size and fitment - but its clearly a different fitment that would require a reworked adjuster mechanism - so not sure if it would work - but it seems like the kind of thing we really need. Whilst designed for commecrial trucks I think its a pretty good match to the 928 elect system requirements...
http://www.bosch.us/content/language1/html/715_5978.htm
See also:
http://rb-kwin.bosch.com/us/pool/usa...nators_FAQ.pdf
http://rb-kwin.bosch.com/us/pool/usa...tput_Curve.pdf
With 2.7:1 crank pulley ratio this will spin at 1800rpm or better even in low idle revving GTS engines.
Anyone fit any other J180 style case alternators?
Alan
Old 11-06-2011, 01:30 PM
pjg
pjg's Avatar
Have you seen anyone selling these alternators ?
Old 11-06-2011, 01:53 PM
Alan
Electron Wrangler
Alan's Avatar
Well there is one on ebay right now...
and http://nationsautoelectric.com/al9960lh.html
Alan
Old 11-06-2011, 06:29 PM
Jim Devine
Jim Devine's Avatar
Bosch al9960lh dimensions & price
http://www.saase.us/final_selection_...o9960_160j.php
Old 11-06-2011, 06:38 PM
928er
928er's Avatar
from the specs that does look to be a nice quality piece...
Old 11-06-2011, 06:43 PM
Speedtoys
Speedtoys's Avatar
Received 1,034 Likes on 623 Posts
So..the question I dont know the answer to, is this mount configuration way outside working easily?
Old 11-06-2011, 07:51 PM
danglerb
danglerb's Avatar
Looks awfully "open" for a bottom of the bay install.
Old 11-06-2011, 09:10 PM
Ducman82
Ducman82's Avatar
could be nice... better then the delco upgrade
Old 11-06-2011, 09:20 PM
Bilal928S4
Bilal928S4's Avatar
Maybe the innards can be installed in the original housing?
Bilal
Old 11-06-2011, 09:49 PM
pjg
pjg's Avatar
Looks like the one Carl shows in his instructions for the 200 AMP HO upgrade.
Old 11-06-2011, 10:06 PM
Alan
Electron Wrangler
Alan's Avatar
Actually it looks very different to me - the case is about 1/3 plastic on Carl's - the Long haul has a 2 part metal case with plastic back + the front plate venting style is different..
The B+connector seems to on the side on Carl's while on the Bosch all electrical is on the back.
Carl's does look a bit like a 180 mount..
Alan
Old 11-06-2011, 10:08 PM
Alan
Electron Wrangler
Alan's Avatar
Open is good for airflow - really they all have to be open to airflow (one way of the other) - with a belly pan on its actualy pretty well protected.
Alan
Old 11-06-2011, 10:21 PM
blown 87
Rest in Peace
blown 87's Avatar
I am all for a better alternator, I had mine custom wound for more amps and I am still not happy.
Old 11-06-2011, 11:03 PM
928er
928er's Avatar
looks like some of the typical ford, as well as what was on some of the range rovers for a few years....
Old 11-07-2011, 10:27 AM
WallyP
Rennlist Site Sponsor
WallyP's Avatar
The 928 alternator lives under the exhaust manifold in a tight compartment. Pulling 300 deg air thru doesn't sound like "cooling" to me. I think that I will keep the cowl and cold-air intake on mine.
Quick Reply: Bosch Long Haul Alternators - anyone tried one?
