Temp II Sensor wiring harness replacement guide - anyone?
Hi All,
I will be replacing the wiring harness for the temp II sensor and was wondering if anyone had done this and can offer some advice or guidance. Still new to the 928 world. I am guessing that it will need to be run thru the dash and into LH pin connector and not sure how to route the wires. Any info would be appreciated.
Thanks,
Ather
Thanks,
Ather
Under the Lift
This is part of the fuel injection harness and not something you can replace indiividually. If the connector/plug is the problem, get a new one and splice it onto the existing harness.
