Roads are getting colder, traction is going down, so what do we do? Add POWER
![ooops](https://rennlist.com/forums/graemlins/icon501.gif)
What's left for today;
O2 sensor bung,
air filter and piping,
BOV,
Connection to MAF,
Vacuum/boost line to rear,
Coolant lines to turbo,
finish tightening all the manifold nuts,
pulling timing out of the MAP, and adding more fuel to the mid range,
I'm probably missing a few things, but will sort them when I get to them.
Should be able to go for a drive later today.
So I have a bone stock engine other than stage II cams, any guesses how much power it will make with 6PSI?
Not the sharpest tool in the shed
That is going to be one loud and quick car.
Not any lower than any other mid mount turbo. Lot more room there than one might imagine.
I'm guessing you will have in the range of 265 or 275 HP
"Roads are getting colder, traction is going down, so what do we do? Add POWER"
Or move to the Southwest where it is warmer and add even more power!!!!!!!!!!!!
Inventor
@daemon,
I have snow tires I will put on when I need to. :P
@hans,
Yes it is one of the oil-less turbos w/ billet racing impeller.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
@Mike,
Yup street car, it really isn't that low, and with 1000/600 spring rates at stock height the car doesn't sink much to hit things.
@hans,
@Mike,
Colin, where is your MAF going to be located? The one I installed is placed back before the turbo intake.
Colin,
What A/R are you running on the exhaust side?? Is this a 60mm turbo? Looks good, glad to see more RMT's or mid-mounts coming out of the woodwork.
You are going to get lots of attention when that wastegate opens up!!
By the way, PM me about how you plan to tune. I have hours and hours invested in a 5 PSI LH tune with 24lb injectors and 7 PSI tune with 30lb injectors......every car is different, but this would get you close.
Sean, I'm going to leave the MAF in stock location. If it doesn't work I will be changing to a different type of MAF.
Mike,
I have stage II cams installed so your maps would be difficult. But I would be interested in the ign maps.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Also the turbo is basically a T76, with a T4 .84A/R, and billet racing impeller.
And yes I know it will likely get loud once the WG open, but I don't mind.![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
I'm going to be going for a 12.5:1 AFR and see how she does.
Mike,
