928 Forum 1978-1995
Sponsored by: 928 Specialists
Trans mount clearance
Old Oct 20, 2011 | 09:42 PM
supercedar's Avatar
supercedar
Default Trans mount clearance
Should the Auto trans be touching the cross member. If not what should the clearance be. I notice mine is resting on it.
Thomas
Old Oct 20, 2011 | 11:38 PM
kelanel's Avatar
kelanel
Sounds like your tranny mounts are collapsed. I know mine are bad but i still have about 1/4 an inch clearance on mine. should be at least an inch of clearance from what ive heard. add shims to level each side when replacing. Im sure someone could give you better specs than me as i cant seem to find much in pet or the wsm
Best of luck,
Jonathan.
File Type: png
Old Oct 20, 2011 | 11:52 PM
supercedar's Avatar
supercedar
Thank you for the info, looks like I need to do the mounts and shims, I did the MM's a couple weeks ago and looks like it put the stress on the trans now.
Thomas
Old Oct 21, 2011 | 12:01 AM
Rob Edwards's Avatar
Rob Edwards
Archive Gatekeeper
Not an auto, but I'd imagine the diff case dimensions are comparable:
Old Oct 21, 2011 | 12:10 AM
supercedar's Avatar
supercedar
Thanks for the picture Rob, My diff is on the cross brace. Iam looking for mounts now.
Thomas
Old Oct 21, 2011 | 01:40 AM
Speedtoys's Avatar
Speedtoys
Yup...thats the photo I asked YOU for when I had the same question.
Got rid of a fair amount of vibration when I replaced those. Wasnt too hard either.
Old Oct 21, 2011 | 10:08 AM
supercedar's Avatar
supercedar
Jeff,
Where did you get your mounts?
Thomas
Old Oct 21, 2011 | 12:38 PM
kelanel's Avatar
kelanel
I know 928rus/928intl/928spec all have the part in stock. heres the part: 928.375.045.16
Jeff, did you have to disconnect the axles to get your mounts off? I also was told by someone that the driveshaft bearings usually are damaged by the fact that the mounts are collapsed, is that true?
Old Oct 21, 2011 | 03:01 PM
ROG100's Avatar
ROG100
Basic Sponsor
We sell them for $135.67 each.
Old Oct 21, 2011 | 04:22 PM
jeff spahn's Avatar
jeff spahn
Without knowing the true answer but just thinking about it wouldn't it make no difference to the TT bearings? The trans, TT and engine are all bolted together. Shouldn't the trans mounts just be a vibration thing?
Old Oct 21, 2011 | 04:45 PM
JHowell37's Avatar
JHowell37
You don't have to disconnect the axles to change the mounts.
Old Oct 21, 2011 | 04:47 PM
Tom in Austin's Avatar
Tom in Austin
I am still trying to figure out how anyone can reach the upper bolt on the right-side mount of a Rogerbox 928 ...
Old Oct 21, 2011 | 05:02 PM
Leon Speed's Avatar
Leon Speed
FWIW there were no shims on mine and no need to add them. Others have experienced the same. YMMV.
I removed the wheel and used a long extension with a knuckle joint. And still it was a PITA.
Old Oct 21, 2011 | 05:18 PM
kelanel's Avatar
kelanel
From what i was reading in the wsm, the spacers were only used as needed to make sure and level inbalances in the mounts were corrected. If the the parts are good, Id imagine no need but good to have a couple of each side on hand during replacement just incase.
Old Oct 22, 2011 | 12:06 PM
supercedar's Avatar
supercedar
Thank you Roger for the great service !!
Thomas
