Jager Speed Mount -* SOLD*
I have a new speed mount I never used. $35 shipped
Here some info on it:
928 Speed Mount New and Improved
Hundreds shipped worldwide and a perfect track record. An easy solution to the vibration and harshness caused by squashed mounts in '83 and newer cars. The "Shark" Speed Mount does not repair or replace your broken motor mounts, it will however significantly reduce the vibrations giving you a smoother, more comfortable and enjoyable ride.
Our Speed Mount is also highly recommended if you are going to be storing your car. Why let the engine sit on the mounts for weeks or months at a time, install our Speed Mount and give your engine mounts a break!
Even if you 928 does not have broken mounts, you will notice a decrease in vibrations with the Jager Speed Mount...a nicer smoother ride for you and your passengers!
A simple 20 minute installation, in between crossmember and oil pan. Reduces failed motor mount vibrations substantially. Design uses engine heat to restore that grumbly 928 into addictively smooth power-on-demand. Molded to the lower crossmember and engine pan surface with a specially selected industrial grade urethane. The new molded material reduces vibration even at lower temperatures.
