Repainting the 1:18 Autoart model
I don't know anything about repainting model cars, but I'm gonna give it a go. Google is my friend
It's supposed to become ruby red.
![](https://img594.imageshack.us/img594/6669/dsc00472hk.jpg)
![](https://img594.imageshack.us/img594/2554/img5718l.jpg)
Only 50 pieces...
![](https://img263.imageshack.us/img263/9688/dsc00545z.jpg)
Trying to remove the white paint with paint stripper:
![](https://img708.imageshack.us/img708/6531/dsc00559pm.jpg)
Apparently over cleaner should clean the plastic parts of paint without damaging the plastic like the paint stripper:
![](https://img143.imageshack.us/img143/6389/dsc00560b.jpg)
Left to right, metal primer, plastic primer, paint, clear coat. The little bottle is the real car color.
Only 50 pieces...
![](https://img94.imageshack.us/img94/8281/dsc00555ga.jpg)
You should use model paint sprayed from an airbrush. The spray can paint is too thick with coarse flakes. The car will end up looking "toyish".
I used to assemble models but don't have time anymore. I ended up giving away a few 928 models such as the Tamiya 1/20 928s several years ago.![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
Steve
Steve
keep posting pics. I may do the interior of my Blumaxx model, and change the black to cork to make it match my car.
The model came apart quite decent. You have to brake off everything as it is glued together. Most parts click/snap off without any damage. Sometimes the little pin behind it breaks off, although a bit of glue should fix that. I did however break a rear quarter window which kinda sucks. That could have been avoided by applying pressure to it over the complete window with two/three fingers. Ah well. My real 928 isn't perfect either ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Good idea about the paint thickness whiteNSXs! I wouldn't want details to get lost, or doors not to close. I don't have an airbrush. Is paint spray can paint meant for car models also thinner than normal can paint? Then I'll replace these cans.
EDIT: I think I'll warm the cans before spraying. A tip I found at the end of this video:
You,ve certainly done a good job in dissecting your model, as has been mentioned you need a good air brush to get an unmottled finish. I was lucky mine came in Minerva blue, but not totally happy about the " heavy " look on the fender returns I painted them a matt black, looks more realistic. Looking forward to seeing your end result ! Good luck.
Fender pic,s--
http://imageshack.us/photo/my-images/11/dscf2070ne.jpg/
http://imageshack.us/photo/my-images/37/dscf2071m.jpg/
Ken
80 928 S
5 Speed
UK
Fender pic,s--
Ken
80 928 S
5 Speed
UK
Little update. Here in old brake fluid:
![](http://img838.imageshack.us/img838/4139/dsc00563resize.jpg)
After a couple of days:
![](http://img40.imageshack.us/img40/1198/dsc00576resizey.jpg)
It wasn't going fast enough, so I sanded it with grit 50![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
![](http://img689.imageshack.us/img689/2946/dsc00580resize.jpg)
In paint remover again:
![](http://img51.imageshack.us/img51/553/dsc00590resizet.jpg)
Cleaned it and sanded it with grit 600. Now it's shiny![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
![](http://img193.imageshack.us/img193/65/dsc00595resize.jpg)
![](http://img543.imageshack.us/img543/5579/dsc00602resize.jpg)
![](http://img820.imageshack.us/img820/285/dsc00608resize.jpg)
![](http://img254.imageshack.us/img254/7720/dsc00610resize.jpg)
In primer:
In primer:
![](http://img838.imageshack.us/img838/7093/dsc00615resize.jpg)
EDIT: I think I'll warm the cans before spraying. A tip I found at the end of this video: http://www.youtube.com/watch?v=nnmJwHNOfmU
Steve
Hi,
Just a tip. Tamiya brand spray paint for model cars is just about the best that I know of from an aerosol can. Give the can a really good shake and warm it up, as you suggested. It gives the best gloss finish that I know of without needing to polish and cut back. (you can still do this if you want to) Tamiya also make a final coating wax to suit.
Just make sure that you get the TS spray for plastic, not the PS spray, which is for radio control car bodies.
No connection, just a long term plastic kit junkie.
Regards,
Jed
Sydney, Australia
83S Kiln Red 3-speed
Regards,
Jed
Sydney, Australia
Don't you wish a full size repaint was this easy.
That stripped body looks spot on what the full size looks stripped.
Looking forward to the final product....keep it up...its looking great.
It was paint time yesterday
I sanded the primer with grit 600 and dusted that off. Then I did two mist coats of lacquer followed by two wet coats. And finally two wet coats of clear coat.
I think I'll polish it next week. I have some old rubbing polish stuff laying around that might work. And I have grit 1200 which might be good for removing a hair that got caught on it. Have to do some more googling to figure out how that works.
Before clear coat:
![](https://img11.imageshack.us/img11/5416/dsc00655resize.jpg)
After clear:
![](https://img26.imageshack.us/img26/3046/dsc00665resize.jpg)
![](https://img830.imageshack.us/img830/9633/dsc00693resize.jpg)
Before clear coat:
After clear:
![](https://img638.imageshack.us/img638/1791/dsc00681resize.jpg)
Cottage Industry Sponsor
This looks very promising! Now I'm just curious how you are going to precisely redo the black trim around the windows... if you can pull this off, the outcome of this project will be really awesome!
Is there any other material you can use to replace the broken rear quarter window?
