928 Forum 1978-1995
Sponsored by: 928 Specialists
Hatch hinge hardware and sealing parts?
Old 10-06-2011 | 11:22 AM
jwillman's Avatar
jwillman
Default Hatch hinge hardware and sealing parts?
I pulled the hatch to address rust in the channel.
When I removed the hatch there was a thin dried fiberous material between the hatch hinge inner matting surface and the body frame. On the inside of the car was a thin rubberish seal material that looked like the mount bolts had been pushed through as the bolt hole was not cut clean. Not sure if either of these was the OEM solution.
I ordered the parts from Roger and item #22 is referred to as a "desk pad" but quantity shows "X" in the PET. The part I received was a thin metal plate so we assime it is a optional shim due to the X qty in PET.
Item #23 is a "gasket" in PET and what I received was a thin fiberous square with pre-drilled holes. One side is peel and stick. Had I not gotten this part in a bag with a PN I would have assumed it was item #22 above as it very similar to what I found during disassembly (god only knows whether the PO did it correctly).
So questions are:
1. What have others found when taking their hatches off?
2. Is the OEM gasket, #23, sufficient to prevent leaks?
3. I am assuming the stick on side attaches to the hardware plate and not the body - can anyone confirm?
4. Are there any alternate best practices to ensure no water leaks, i.e. alternate seal materials?
Old 10-07-2011 | 10:41 AM
jwillman's Avatar
jwillman
Bump,
Certainly I can't be the only 928 owner who has ever pulled the hatch frame!
Any experience is welcome as always.
Old 10-07-2011 | 11:21 AM
4drgl's Avatar
4drgl
Default Hatch Hinge seal
I'd be interested to know as well...
Mine were adhered pretty well, but I didn't t hink they were stick on's thought they were more like insulators..
Old 10-07-2011 | 02:29 PM
Jeff928S4's Avatar
Jeff928S4
The hatch hinge seals will be on my next order from Roger. I figured they would be a rubber piece.
When the hatch seals leak, where is the water passing through....by the bolts?
Old 10-07-2011 | 11:01 PM
LeRox's Avatar
LeRox
Not sure this is of much help but when I had the exterior refresh done (rear hatch was removed), I noticed water drops on the rear drivers side visor after washing the car. I concluded that water was coming in via the rear hatch hinge via the bolts. I have not addressed this yet since the car is usually under cover and will probably use a clear silicon sealant or equivalent to address this in conjunction with the thin fibrous square provided with the kit (if I had it).
Old 10-08-2011 | 12:05 AM
risaac928's Avatar
risaac928
Can you post some pics or videos...I think mine leaks too. Everytime I wash the car I noticed some water creeping in...
Old 10-08-2011 | 10:39 AM
jwillman's Avatar
jwillman
The first picture is the outside body hinge mount point. Note holes are square to allow for adjustment of hatch to car.
Second photo is the new "gaskets" by PN from both Roger and 928 Intl. Next to the new ones are the old ones removed from my car. The new ones have a peel and stick on one side which I attached to the hardware plate. If you mount them to car they would restrict the movement of the bolt within the square frame hole and thus adjustment of the hatch.
Third photo is the hardware plate without gasket attached and the "desk pad" that are the optional shims that mount between the hatch hinge and outside car mount pad to provide additional adjustment of hatch alignment.
Old 10-08-2011 | 12:57 PM
EC928NC's Avatar
EC928NC
I'm following this thread for info on your final adjustments. My hatch has a 3/8" gap along the top edge and overhangs slightly at the back. My inclination in looking at it is that the brackets need to move "up" to get it to close the gap, but in the three times I've tried I couldn't get it any closer to the 1/4" gap it shoud have.
Old 10-08-2011 | 07:51 PM
jwillman's Avatar
jwillman
I made my adjustments before installing the glass. I moved the hinges to the highest point (push hatch at hinges up as high as it would go) then snugged them up. Hatch is even with the roof line and sitts much better than before. I did not use the shims between hatch hinge and outer body.
I had also removed the hatch lock assembly and struts before adjusting.
Old 02-27-2012 | 09:33 PM
silbershark's Avatar
silbershark
Will leaks from the hatch hinges follow body panels and leave a puddle in the rear floors?
