928 Forum 1978-1995
Sponsored by: 928 Specialists
what weight/type engine oil do you use?
Old Oct 3, 2011 | 06:21 PM
dogleg's Avatar
dogleg
Default what weight/type engine oil do you use?
just coming up on 2k mls since my last oil and filter change and im considering using some 20w50 classic oil id stocked up on during ownership of my last classic car (non porsche). first few changes on the 81 928 i used 10w40 semi syn.but just did a tread search and found lots of people on here using the 20w50,but the tread was from 2003!!should i use the oil i already have or play it safe with the modern stuff?the 20w50 i have is high quality......mark
Old Oct 3, 2011 | 06:33 PM
Fogey1's Avatar
Fogey1
Originally Posted by dogleg
... considering using some 20w50 classic oil id stocked up on during ownership of my last classic car ....mark
How long ago? When I checked some Quaker State I'd had >10-15 years, the bottom .5" of the (plastic, screwtop) containers was wax. I didn't use it.
Erin go bwaah .....
Old Oct 3, 2011 | 06:46 PM
joejoe's Avatar
joejoe
20/50 castrol here.
Old Oct 3, 2011 | 06:54 PM
928er's Avatar
928er
anything AMSOIL per MK....
Old Oct 3, 2011 | 07:12 PM
dogleg's Avatar
dogleg
[QUOTE=Fogey1;8917209]How long ago? When I checked some Quaker State I'd had >10-15 years, the bottom .5" of the (plastic, screwtop) containers was wax. I didn't use it.
bought 2 gallons of it in oct 2010 cans are still sealed been stored in my house since,so should be fine.good point though hadn't considered that.
Old Oct 3, 2011 | 07:46 PM
ammonman's Avatar
ammonman
Mobil 1 15W-50
Old Oct 3, 2011 | 08:30 PM
RCinXS's Avatar
RCinXS
Royal Purple Synthetic 20W50.
Old Oct 3, 2011 | 08:54 PM
Hilton's Avatar
Hilton
Simple..
1. Look in your owners manual
2. Select the recommended weight for your climate range (likely 20W50)
3. Identify locally available oils in that weight
4. Figure out which of the locally available oils has >1100ppm of ZDDP in it
The tricky part is step 4 - most oil manufacturers don't publish that info so you'll likely have to phone their technical helpline.
Also be aware that formulations differ by country - so Mobil 15W50 may not have the same level of Zinc in it in Ireland as it does in the US due to differing standards regionally (API vs. ACEA vs. JASO etc.), as well as regional fuel differences (levels of sulphur, available octanes etc)
Old Oct 3, 2011 | 09:03 PM
hacker-pschorr's Avatar
hacker-pschorr
Administrator
Have these engines changed dramatically since then?
Old Oct 3, 2011 | 09:15 PM
Bjbpe's Avatar
Bjbpe
Speaking only as an aerospace engineer with a raft of experience on jet and rocket engines - we only used synthetics on high temperature applications
Old Oct 3, 2011 | 09:49 PM
jeff spahn's Avatar
jeff spahn
Ditto on the whole post.
Old Oct 3, 2011 | 10:05 PM
GlenL's Avatar
GlenL
Amsoil, baby.
Old Oct 3, 2011 | 10:10 PM
risaac928's Avatar
risaac928
Mobile 1 15/50.....every 3-6 months...
Old Oct 3, 2011 | 10:22 PM
Speedtoys's Avatar
Speedtoys
If you use Amsoil..dont use too much.
I read somewhere it soaks into the metal, and not only makes everything lightweight, but entirely friction proof as well.
Only takes a few quarts.
*kidding*
Old Oct 3, 2011 | 10:46 PM
ALKada's Avatar
ALKada
*kidding*
