Rear hatch metal glass trim repaint
If you mean the actual hatch/lid glass, I would,nt disturb it unless it,s broken glass you need to replace. The glass is bonded to the hatch frame and it usually breaks if you try to remove it. Removing the glass is a pretty specialised job, the outer aluminium trims have to come off, a nerve wracking job in it,s self as they are easily bent, once they are out, you need to access entry through the mastic so you can get a cheese cutter in there, and use a sawing motion right around the whole of the glass, till you meet up where you started, and if you have,nt broken the glass by now.., the glass lifts out.
The leak may not be the seal but the screws that go up from the inside of the hatch to hold the outside trim. The hatch seal is pretty thick stuff and you can inspect that and the screws by removing the interior hatch trim which is easy to do. I'd check the screws and their little seals. Look for traces where water may be draining and flowing down the interior hatch trim. You can fix leaks on those screws by removing the screw and putting a dab of silicone on it and reinserting screw.
Chronic Tool Dropper
Are you sure it's the glass that's leaking? The hatch seal itself is notorious for leaking top/middle where it meets the lid. Telltale is that there's water markings on the painted steel and the interior trim right at the top edge of the hatch. When the glass leaks, the water drips from the glass and/or from the third brakelight.
The hatch seal is new within the last 8 months. There is a wet spot on the glass sealant when it rains that drips down the glass and onto the interior trim and then onto the rear center console.
Leaving water spots all along the way. I'm pretty sure it's the sealant that is failing.
Thomas
Supercedar, If your grid is bad, repaint it. Use a VOM to find the break(s) in the grid. Clean the damaged areas, mask off and repaint the lines. Check E-BAY under r/c airplane parts for conductive paint and glue. If the edge contact is broken off the grid, you can re-glue it with the r/c silver glue.
Administrator - "Tyson"
Anyone remove all the trim and have it re-anodized?
