Help with power steering rack.
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
I need some help to locate an '0' ring, number 6 in these pictures. My bad,I thought it was included in the kit Roger sells because I saw it in a post from a while ago, should have checked but much water over dam. thanks for any help.Ray. Oh its off my 86.5 I hope.![Name: annotated_complete_seal_set_2.jpg
Size: 70.3 KB](https://rennlist.com/forums/attachments/928-forum/570850d1317575453-help-with-power-steering-rack-annotated_complete_seal_set_2.jpg)
![Name: zf_rack_exploded_diagram.jpg
Size: 102.0 KB](https://rennlist.com/forums/attachments/928-forum/570851d1317575453-help-with-power-steering-rack-zf_rack_exploded_diagram.jpg)
If you are talking about the white palstic(teflon/delrin) seal that has the black o-ring under it that seals the fluid between left and right side of rack? see this page>http://forums.pelicanparts.com/porsc...begins-10.html "I rebuilt the steering rack with a kit from Rennbay. Everything went good and I will cross my fingers that it doesn't leak. A couple of seals were wrong in the kit. They were the ones on the center part of the shaft that seals the left side from the right. I probably didn't need to replace these seals(plastic and o-ring under) but I had already cut them off. I was able to find the seals at an aircraft seal supply place run by an old couple. They let/helped me look through the building until I found something that would work. I had to grind(Dremel) the non-critical inside diameter some to make this Delrin seal fit over its carrier. The rack boots were a struggle to install especially when my hands got tired from the struggle."
If this is it I have a couple of extra I can send you. The merchant gave me a handful. I will send you one I fabricated and one that is unfabricated. Give me your name and address. Gunar
Basic Sponsor
Ray & Gunnar,
You both have the same kit - mine are from Rennbay as well.
It is the only available kit that I am aware of. Maybe the seal was just missing from the kit???
Is it item #26 in the illustration that you are missing and are those dimensions correct?
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Hi Roger,hate to bother you,know you about as busy as a one arm paper hanger (no offence ) anyway it is #6 i believe, Gunnar has kindly offered a replacement and i am taking him up on it. I suspect that ring is no longer put in the kit for some reason. If Gunnar did not get one and i did not get one? You might go back to supplier and question that thou. Thank you both,Ray
The last Rennbay/Roger kit that I got included only one such o-ring, which I believe was intended as a replacement for #6 not #31. The latter is a non-critical o-ring, just there to make sure the puddle on the floor comes from the end of the rack and not the cover plate (#34).
The other part that I believe is not included in the Rennbay/Roger kit is the #30.1 "saddle" liner (incorrectly marked as "10.1" in the photo). This is the plastic bushing that supports the rack at its engagement with the pinion. It is a wear item, as is the #24 bushing at the other end. The rack rod is supported between the #24 busing on the passenger side, and on the driver's side between the pinion gear and the guide block (parts #30-34).
Cheers,
O-ring #6 (the backup o-ring in the center piston seal) and #31 (the o-ring on the saddle-shaped guide block) are very similar- perhaps identical. They are "fat" o-rings of around 32mm OD, 26mm ID if my notes are correct.
Cheers,
Cheers,
![Name: DSCN1873.jpg
Size: 77.5 KB](https://rennlist.com/forums/attachments/928-forum/571086d1317655956-help-with-power-steering-rack-dscn1873.jpg)
![Name: DSCN1874.jpg
Size: 110.5 KB](https://rennlist.com/forums/attachments/928-forum/571087d1317655956-help-with-power-steering-rack-dscn1874.jpg)
Well i may have had it wrong let me try to put up a pic of my steering rack.Attachment 571086
Attachment 571087 maybe i had the # wrong but you can see it here.
I mailed it today. In my Rennbay kit I was also missing the black rubber o-ring that goes under the delrin plastic one I am sending you. I have extras but the sizes all look similar. Let me know if you need this also. Gunar
![Talking](https://rennlist.com/forums/images/icons/icon10.gif)
Gunar, I got the part and i thank you,will put it on tomorrow. The mail to 04655 is a little slow.
Hey Roger are you getting your suppliers to put this back into the kit? Should be there. Best to the both of you,Ray
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
