Bushings in the rear suspension...
Developer
I am about 2 months into that project already. Had a pause to go to Bonneville.
We have poly bushings in hand now for some of the rear links, and I am molding or locating the others. I hope to have some rear polyurethane kits out by Christmas.
These bushings handle a Bunch of pressure and pulling. I would be concerned about delrin "running" or what some call "cold flowing".
Maybe its good that I am no longer waiting and just putting "A" car together with all the pieces I have collected since 2000. I'll have one car with all the pieces that are no longer made - gears, bushings, seals, etc.
Well, guys thanks for the input. In any case I ordered 2 main bushings and 4 of the dog bone bushings as per Roger and Mr. Merlin. As I have a low mileage example that should do me. I think the bushings for the pin connections will not be required.
Developer
Carl,
That is great news to hear. I guess I will hold off on my purchase then. Will your bushings be replacement for all rear bushings (specifically lower rear control arms) and will they have the same hardness as factory, or will they be "near-zero deflection" ?
Cheers!
Carl
1990 GT
Cheers!
Carl
1990 GT
Developer
At the moment, I am focused on shock bottoms in the rear. I am making an adapter that will allow the use of any race shock with a standard 1/2" heim joint top and bottom... this will open the world to us 928 owners away from just Koni's or Bilstein's. That's what I have nearly completed.
I have the last new rubber parts for the rest of the rear links from Stuttgart to model off of in my possession, and after I finish the shock mounts, I will be going through the rest of the rear suspension one-at-a-time.
