Pool of oil beneath Thermostat cover
Doing the cambelt and WP, pool of oil on the flat rectangular area on top of block below and behind the Thermostat housing. What is the most likely source? Car has 60,000km. Thx/T
you wont be able to tighten these bolts easily if at all unless the intake is lifted some.
If you lift the intake then you might as well remove it
then it will be easy to reseal the fill tube and add the 928 INTL oil block off plate.
I suggest to use a generous amount of hondabond to the sealing surfaces including the O ring seal
