928 Forum 1978-1995
Sponsored by: 928 Specialists
Coolant Leak Drip - What Is This - FIXED w pics - need help?
Old 09-23-2011, 08:58 PM
  #31
joejoe
joejoe's Avatar
San diego not sure if you addressed the fitting in the second picture yet but if the same as on my 86.5 it is a pressed in and glued fitting. If it lets go you will lose nearly all coolant in about 30 seconds. I need to look at the '81 before heading down to sharktoberfest now.
Old 09-25-2011, 03:13 AM
  #32
SanDiego928
SanDiego928's Avatar
Yes, thanks, I ordered the assy. and thermo valve on Friday. Next week I'll have both parts. With some luck I will have fixed the coolant leaks, vacuum leaks and will have an idle that stays where it should before Shark Day in Anaheim.
Quick Reply: Coolant Leak Drip - What Is This - FIXED w pics - need help?
