Best methodology for making wiring harnesses
hey all,
What do we think is the best way to make wiring harnesses? I have aftermarket ECU and I would like to make a harness (a spare) that is modular so that it can be disconnected from the engine in the bay and moved to a different engine with minimal pain. I was thinking of incorporating 25-pin DIN connectors (or the like) to achieve this, since they are shielded and can be screwed together in a secure fashion. Is this a terrible idea?
If the idea is sound but I should be using a different sort of connector, what should it be? I have two-conductor shielded wire for the knock sensors and crank position sensor. Should I be using single-conductor shielded wire for any others (I have a pile of mil-spec Teflon insulated silver strand, silver shield wire ready to hand)?
The car will have MAP, TPS, ISV, intake temperature, water temp, injectors, flappy actuator.
Any suggestions/advice/ideas would be welcome. The car runs fine now with the harness that I've built, but I'd like a spare to swap in as I have a backup engine that I would like to work on, and two harnesses are obviously superior. Plus if I build from scratch to a connector, I can perfectly optimize all of the lengths, etc so that the harness is easily removable.
Also, does anyone know off the top of their head the diameter of the hole in the boot/grommet that goes through the firewall that is connected to the engine harness?
EDIT: Wait, better idea. Does anyone know the size of the hole in the firewall? It's probably easier to source an appropriate (and new) grommet than to tailor connectors to fit. I would like to use something like this
Administrator - "Tyson"
^^^^^Man would that make pulling the engine a snap
Yes, that is the other motivation....
EDIT: I've thought about this a little bit more. I like those weatherpack units, but just out of curiosity, I priced mil-spec connectors that have a threaded locking mechanism and strain relief, and to get enough connections through the hole in the firewall in reasonable wire sizes would cost somewhere around $340 for the connectors alone. They would be pretty, but not $340 pretty methinks. At that price I could buy about 7 sets of those 22-pin jobs. It's hard to tell how good the strain relief would be, but frankly, at that price I could just fill the connector with epoxy once it's connected and forget about it. If something needs replacing I could cut it out and put a new one in (although admittedly wiring that is a pain in the butt) and still be way ahead. Normally I hate kludgey fixes, but this one is somewhat tempting, I must admit. Perhaps I could make a strain-relief bracket in the machine shop...
How much strain are you expecting to deal with?
I've been thinking about using two of these when I drop CIS from the 79:
http://www.amazon.com/Delphi-Packard...6054111&sr=8-6
I don't expect much at all, but I prefer to overbuild things where possible. Overbuilt is the German way, after all. In this case, though, I don't think it's worth doubling the cost of the harness...
Does anyone know of a source for the 10-pin connectors used in the factory wiring harness (plugs V and W I think)?
