928 Forum 1978-1995
Sponsored by: 928 Specialists
Shocks M474
Old Sep 11, 2011 | 11:15 PM
BRB-83-911SC's Avatar
BRB-83-911SC
Default Shocks M474
84 Euro S with M474 - I have gold Bilsteins with adjustable perches in the rear, and green (Bilsteins??) with non-adjustable perches in the front. Shouldn't I have gold Bilsteins with adjustable perches all around?
Old Sep 12, 2011 | 02:08 AM
jpitman2's Avatar
jpitman2
Mine is an 83S with M474 - same on the rear as you quote, but I have replaced the fronts with new gold Bils, which came with adjustable perches. Dont recall what colour the originals were.
jp 83 Euro S AT 53k
Old Sep 12, 2011 | 11:06 AM
soontobered84's Avatar
soontobered84
I don't know about the shocks, but you should've had adjustable perches all the way around. Somebody has swapped your perches.
Old Sep 12, 2011 | 11:12 AM
Jadz928's Avatar
Jadz928
^ +1 Front shocked are swapped. Should have Bilstein "golds" all around for MY '84 w/ M474
Old Sep 12, 2011 | 02:01 PM
BRB-83-911SC
Thanks all, confirmed my suspicion.
Old Sep 12, 2011 | 06:48 PM
jpitman2's Avatar
jpitman2
Sure the green fronts are Bilsteins? Arent Boges green? My M474 car did NOT have adjustable perches in the front, and from all I have read thats normal.
jp 83 Euro S AT 53k
Old Sep 12, 2011 | 08:00 PM
Bill Ball's Avatar
Bill Ball
Under the Lift
Changed to adjustable perches in 84. The early Bilsteins were green. The Boges were black.
Old Sep 12, 2011 | 10:34 PM
BRB-83-911SC
Hmm, probably moot point anyway as I will eventually put gold bilsteins with adjustable perches in the front - more a curiosity at this point. So, 83's with M474 came without adjustable perches. Any chance that spec could have carried over into 84 (mine's a Euro if that matters - fairly early at VIN 0849)? I have PO records, but no mention of a shock change, and the car has less than 40k miles - green shocks, no adjustable perches on front.
Old Sep 12, 2011 | 10:54 PM
Ispeed's Avatar
Ispeed
I took a look at it on a lift and didn't know what to think. If the cosmolene looks original and the bolts look untouched then I would vote for original.
Old Sep 12, 2011 | 11:10 PM
BRB-83-911SC
yep, Carl, you got me wonderin'
Now, off to wonderin' about other things....
