Team Owner
these are for early 16 V engines say 80 to 84oil drain back tube,
of course you need the oil pan to match
the later pans had this hole cast over .
Inventor
'80-'84 tubes are curved to go around the PS mount bracket, and bolt on. These can be mounted to the later pans with a cover plate with some trimming(?) of the tube. (EG. for an oil separator drain.)
Electron Wrangler
Stirling,
Since your pan doesn't have that port - why not just drill and tap it for a standard fitting and go with new tube to whatever filler/provent etc you plan to have...?
I'm actually having that done to mine right now as a new filler port - (Provent breather from the stock filler makes that such a pain to use...)
Alan
Alan
This was used up to 87, my early 87 has the pan with a block off plate.
Why not get the early pan with the different oil pickup, will still need the tube.
Good luck,
Good luck,
