No parking or tail lights 94 GTS
No parking or tailights. No listing on the fuse panel. 94 GTS Auto. The headlights, brake & driving lights are fine. TIA. T
Archive Gatekeeper
Someone jostled/pulled your lamp control module connector in the process of R&R'ing something during paint and interior? Brad hasn't been near your car, has he?
https://rennlist.com/forums/928-foru...il-lights.html
Under the Lift
How about the license plate lights? If they are out too, you might check Ground Point VI, which I think is at the front of the spare wheel well.
I'll check on that connection Rob. I don't think Brad has been in the area as of late. Bill, forgot to mention that the license plate lights are working. Thank you, T
Rennlist Site Sponsor
Fuse #7 feeds the left lights; Fuse #8 feeds the right lights.
If all, front and rear, are out, there is no common ground and no common power feed. The last common point for all side lights is at the light switch.
With the lights on, check for voltage/power on the tiny metal bits in the faces of Fuses 7 & 8 - check fuse contact to ground. If you have power on all four bits, the next step is the bulb monitoring computer.
