928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine Identification
Old Sep 2, 2011 | 12:10 AM
944/951guy's Avatar
944/951guy
Default Engine Identification
The 1991 928 GT I was going to fix has a blank spot with no numbers where the Engine code is supposed to be under the coolant neck. Is there a reason for this??
Old Sep 2, 2011 | 12:14 AM
James Bailey's Avatar
James Bailey
Yes either the block was replaced usually under warranty or the car has a stolen engine with numbers ground off....or it has an S-4 engine and some one wished to hide that fact.... Those are the choices.
Old Sep 2, 2011 | 12:15 AM
944/951guy's Avatar
944/951guy
Ill go for the first one. Definatly doesent look Ground off.....
Old Sep 2, 2011 | 12:18 AM
James Bailey
They seldom do but it is very rare for 928s to be stolen....too hard to sell the parts.
Old Sep 2, 2011 | 12:34 AM
Hilton's Avatar
Hilton
From 87 onwards, the engine number plinth was machined at the same time as the water bridge surface - so it should be exactly level with there.
Prior to that, it was left as a rough casting (928 bocks are sand-cast) so any tampering is very evident.
One of my 928's has a plinth with no engine number - just the letter "ATR", which is a factory stamp on some warranty blocks.
Old Sep 2, 2011 | 03:42 AM
karl ruiter's Avatar
karl ruiter
I put a factory new block in my '79, and the patch for the numbers was not machined at all, just rough casting.
Old Sep 2, 2011 | 01:45 PM
944/951guy's Avatar
944/951guy
what is the water bridge surface?
