Rough running problem (long)
And an ignition misfire will show as "lean" on an AFR gauge, which matches the symptoms. (A misfire leaves unburned fuel plus unburned O2, and AFR is measured with an O2 sensor-- not a fuel sensor).
Jim said the coils were new, correct? Both of them? I would go through everything on the secondary (high voltage) side of the ignition circuit-- anything that hasn't been changed/swapped since the problem started.
And also check the 12v side of the coil, make sure it is really 12v with the engine running (should be a direct connection to bus 15). And check the ground connections to the coil drivers.
Good hunting!
Rennlist Site Sponsor
I would lean toward a fueling issue for a couple of reasons:
With two individual ignition systems, a failure of one system should show up on the ignition monitoring relay - that's why it is there.
There are few failure points that will cause intermittent operation of both systems. Perhaps ignition switch or wiring fault in the primary side.
No mention of a wavering or falling tach needle, which should follow most of the faults that affect both systems.
Last time I was at Harbor Freight, I was tempted to buy their electric oil pressure gauge. Stick the sending unit on the fuel rail, run a wire in thru the passenger window, hang the gauge on the ash tray, and have real-time monitoring of fuel pressure. Might be something to consider in your case.
928 Collector
Hi Jim, sorry you're having no fun!!! If it were me, I'd replace the o2 sensor just for grins at this point. Seen this sort of thing with frayed O2 sens wires.
Very best wishes,
Heinrich
Very best wishes,
Heinrich
Out there, but could it be possible for an injector to short internally? Or to have one bad one?
Even if new 2 years ago, reading between the lines, this still might be worth checking or swapping.
Not sure if data logging is possible. Or if only one bank could be affected by this on GTS.
OK, so you've replaced everything. You still have no good information as to whether the events are fuel and/or ignition related. I would feed a wideband to a Sharktuner and see what it shows during one of these events. The wideband, even w/o Sharktuner, will show you if you are going lean. I know it's not exactly simple to log with Sharktuner if the bad events are very sporadic and you are driving around alone.
It could be injector-related, but know that a short anywhere in the harness takes out all the injectors as they share a common ground. However, one problem I've seen a lot with the factory injector harness plugs is loss of the wire retaining clips. They tend to fall off and the plugs are free to lose contact. One 87 I worked on had 5 missing clips.
I suppose you could have an intermittently bad coil and not have it picked up by the ignition monitoring system, but I think that would be odd.
All the injector clips are in place. Thanks Bill.
Missing under load sounds like ignition, something arcing or shorting on the high voltage side. The spark voltage goes up with load-- increased combustion pressure requires more voltage to fire the spark plug-- and if something else "fires" first, then no spark.
Good hunting!
Good hunting!
When you tried the spare LH/relay combo, did you check for any LED's lit when the problem recurred? I'm thinking there is a possibility of a bad sensor on one of the exhaust manifolds triggering the 4 cylinder mode. Jumping the relay is a quick, easy test. Of course if you checked for a lit LED, this is all moot...
It IS possible to purchase defective new electronics. Although a new/rebuilt MAF was fitted, a bad MAF has not been ruled out positively. I would replace the MAF with a known good MAF to absolutely rule that out before I went much further.
Jim,
The symtoms sound like a bad MAF, very similar to my old '84 Euro. Biggest diff. I didn't hear the term "bucking", where it stumbles heavily... then w/ enough throttle, revs.
Other thing that coming to mind when I think of 2 coils, 2 ign. circuits are the 2 coil amps. I have a feeling they are nearing the end of their life-cycle, in general.
If you haven't replaced them (from what I read, you haven't), change them.
Basic Sponsor
Rebuilt MAF fitted and nothing changed regarding the problem - car ran generally better overall as one would excpect.
Jim,
I will be camping this weekend but will be semi-local (up at Ray Roberts in Sanger). I will get the Sharktuner and wideband out of my car and see you Saturday at the GTG. We can have it hooked up in 10 minutes (can somebody bring a jack?) and see what is going on with your AFR.
Okay guys, an update. Drove the car to and from work today. NO bogging on either trip, but it would not idle until fully warmed up (end of a 20 minute drive) but even then at only about 3-400 RPM. My PEMS are set to GT idle of 850-900 RPM.
Tonight I checked the ground wires to the coils 0.4 ohms for each. The coil wires are factory and were ohmed when I put them on 30 days ago, along with new caps and rotors. One coil is new, drove the car with no change so moved the new coil to the other side and re-installed the 1st coil on the 1st side. Still no change so I believe both coils are good. Also checked the Temp II with the car still warm (4 hrs after shutdown) RH contact reads 688 ohms and the LH reads 687. I'll check them again in the morning when everything is cool. Also checked the injectors, all wire clips are present and the rubber boots are still soft and pliable. I believe this harness grounds at the back LH side of the block. I cleaned that ground last night, although it looked good with no corrosion and was tight.
When it was bogging the tach and speedo indications are always normal with no flucuations so I don't believe the ignition switch is faulty.
We have a sharktuner locally so I may have to get it back on and try to log the A/F ratio better than the ARM-1.
My S4 had the 4 cylinder mode symptons, but it's an '88.
Turned out that one of the wires going to the output stage had worn though its casing behind the fuse panel. It was intermittent because it would only short out when it contacted metal.
If everything is new and checks out Jim, it may be worth poking around the fuse panel and just making sure all the wires are in order.
Jim - I have a ST2 and could come down Saturday if necessary. Just let me know...
Jarrod, thanks, we have a sharktuner locally plus I have to work Saturday so I may be leaving the GTG early. May just swap cars with someone if we get our sharktuner on it. Maybe get Mike to give me his turbo to try while he messes with the sharktuner. :-))))
Shameful Thread Killer
I need to get an oscilloscope on the outputs of the injector lines for both batches. It sounds like an intermittent short in the injector harness. I'm avail on Thursday, but going out of town for the weekend. Let me know. If that tests out good, we can monitor the ignition final stage inputs/outputs and make sure there's nothing funny there.
A failing ignition problem will create either the IMS shutdown, or it will backfire with unburnt fuel in the exhaust. I'm pretty sure this is a fuel metering problem. It can also be causes by incorrect resistance on the injectors themselves. Either a short, or an open circuit can affect all four injectors in the batch. That will make it run funny, without any IMS trigger or backfiring.
<edit: I think my Oscope is at Rogers house if you want to use it yourself. I can find the test points for you, or we can connect and do it together.>
