used 32V lifters needed
Administrator - "Tyson"
I have a set of used lifters from my 944S (same part number) that are sitting in a Tupperware container that are free if you want them. - 16 of them.
The engine coughed up a rod bearing, no lifter related issues before that. They are probably fine, I bought new ones because I was told to do so
The new VW lifters are cheap and work well.
Remember you cannot blame parts failure on the mechanic when you insist on the mechanic using old, untested parts.
So unless you have a desiring for another opening of this motor, buy new.
Basic Sponsor
If enough people are interested I can do the lifters for $10 each 8>)
VW Lightweight Lifters - I have them in my own GTS.
![](https://cdn.shopify.com/s/files/1/1694/8685/files/928sRus_rennlist.png?v=1621798567)
Does it have the "Do It Yourself" manual transmission, or the superior "Fully Equipped by Porsche" Automatic Transmission?
George Layton March 2014
928 Owners are ".....a secret sect of quietly assured Porsche pragmatists who in near anonymity appreciate the prodigious, easy going prowess of the 928."![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
Former Sponsor
The lifters do come apart, so you can disassemble them and clean them. I have a ultrasonic cleaner and that works really well. You can also examine/clean the pieces that make the filter work hydraulically, so there is no risk of installing a "bad" lifter.
We used to do this only with lifters in engines that had "issues" with failures of some component, but now we do it whenever we do a rebuild. That "shelf" inside the lifter collects a bunch of debris.
Man of many SIGs
Former Sponsor
Not usually. I generally keep lifters with the orignal cam lobe and I don't see any advantage to messing with them, once they are worn in. On engines that I don't know where they came from, or when I might use a "used" cam, I do "lap" them.
New cams get new lifters....which is a completely different subject. They are a complete mess....there's a good reason the VW ones only cost $10 or $12. Buyer beware! It takes us 40-50 lifters to find 32 that we can use....and by the time we determine that we can't use them, they are not returnable. I've got a pretty big box of brand new "junk" lifters.
Basic Sponsor
Sold hundreds of VW lightweight lifters over the last six years with NO issues what so ever - have them in my own cars with no issues.
But then again I do not build $60,000 stroker motors?
I guess next you will say they are made in China 8>) and we know they are not.
Scary to think that the Porsche lifters are so bad!!!
So lapping compound and smooth the tops? Let's just hypothetically say you don't know where the lifters came from because you knocked them over and got mixed up. Rub the lapping compound on the double thick glass on the counter top and make them smooth once again?
