928 Forum 1978-1995
Sponsored by: 928 Specialists
I'm going to shoot my car
Old 08-19-2011, 10:21 AM
Jfrahm
Jfrahm's Avatar
If your rotors are worn, the lip that sometimes develops on the outer circumference of the rotor can cause a *very* annoying screech.
This lip can be easily felt when the brakes are cool. Careful, it may be sharp!
-Joel.
Old 08-19-2011, 11:43 AM
Troy Barnes
Troy Barnes's Avatar
Just put on some anti-sieze! Easy cheap fast and it will shut them up. Don't get any on the pad faces or rotors. On the groves where the pads slide too!
JMO
Good luck.
Old 08-19-2011, 11:52 AM
Tampa 928s
Tampa 928s's Avatar
I have tried various brands of pads and f your going to replace them use the one's from Roger. I would have the rotors ground if there is enough left and go with new pads. I cannot tell you the difference a pad makes when my wife says honey the car is not stopping like it did before, I took notice!
Old 08-19-2011, 12:22 PM
cali4sun
cali4sun's Avatar
Shoot It!!! Well someone's gotta say it!
'89 S4 GP White/Black
'76 912E Silver/Black
Old 08-19-2011, 12:57 PM
TYP928S
TYP928S's Avatar
If your brake hardware is 24 yrs old them is already shot...
Springs lose springy-ness over time
jon '84 us auto
Old 08-19-2011, 01:07 PM
stevedavies
stevedavies's Avatar
This 911 owner had issues with his car too!!
Old 08-19-2011, 01:17 PM
cali4sun
cali4sun's Avatar
He probably was beaten by a 928
Old 08-19-2011, 01:21 PM
TYP928S
TYP928S's Avatar
or has very bad aim, look none of the clay pigeons are broken....
jon '84 us auto
Old 08-19-2011, 02:27 PM
928mac
928mac's Avatar
Originally Posted by macfly4
I'm starting to lose my mind. I know there are other threads on this but I just wanted to vent. My brakes now sound like they are banshees heralding the death of someone in the near future. I shake with trepidation when 'cruising' slowly in high visibility, swanky boulevards because I know that as I touch the brakes to come to a slow stop the heads will turn as the squeal of torture screams from my brakes.
Washing the car seems to help for a short time. Taking high speed runs and short quick stops helps for a very short time. Cruising on the highway at 60 with one foot soft on the brake and the other still on the accelerator helps for a short time...but recently, the banshees return with all too unappreciated frequency.
Should I just buy a new set of rotors and pads and be done with it or do i just need pads with 'dampers' or something? How do I know if it is the pads or the rotors.
Please help me before this beautiful car is full of buckshot.
OK so you are not comfortable doing the work your self?
Maybe someone can come over and give you a hand.
no matter how you deside to get it fixed
as a mechanic I would say
You need to have the glaze removed from your rotors by replacing them or by having them machined.
Also the pads more then likely have been chared from you riding the brakes and over heating them. They get a charcoal finish which will sgueel like a rock on a blackboard.
Summery needs new pads and rotors or new pads and the rotors machined. I am sure any corner garage can do it but do your self and your car a favor and make sure it is a repritable shop with a licenced mechanic, not a speedy brake stop shop.
Call a member close to you and save the labor and buy the parts from Roger is the least expencive way to go.
Old 08-19-2011, 02:35 PM
Jerome Craig
Jerome Craig's Avatar
PM sent.....give me a call.
Old 08-19-2011, 04:16 PM
Mike Frye
Craic Head
Mike Frye's Avatar
That's what I'm talking about.
Old 08-19-2011, 04:56 PM
the flyin' scotsman
the flyin' scotsman's Avatar
way to step up and help out......excellent
Old 08-19-2011, 05:08 PM
WyattsRide
WyattsRide's Avatar
Maybe he has a shot gun to loan him?
Old 08-19-2011, 05:41 PM
the flyin' scotsman
now that kinda comment just invites all sorts of Amsoil vs Mobil 1 or Torque vs HP type discussion as 'someone' shall state that an appropriate calibre rifle should be used or calibre of shotgun pellets etc etc
its Friday
Old 08-20-2011, 03:10 AM
macfly4
macfly4's Avatar
Thanks Jerome (PM sent) and all. not knowing exactly what to look for i went and looked at the rotors. they do seem to have a small 'lip' around the edge but nothing extreme. but for all i know this is too much. having them machined seems like a good option rather than buying new ones. everyone keeps referring to Roger but is there a direct link to his shop? sounds like the best way to go.
Quick Reply: I'm going to shoot my car
