928 Forum 1978-1995
Sponsored by: 928 Specialists
Question of DIY X pipe
Old 08-15-2011 | 01:14 PM
vinyl_tien's Avatar
vinyl_tien
Default Question of DIY X pipe
Hi
I Live in Taiwan, want do DIY X pipe for my 89 S4.
I saw a lot pictures.
Is the X pipe is (engine side) two tubes into one tube than two tube.
Or They cross like a X shape? the X sport is joint or not joint?
need you guys input. Many thanks!
PS. I know I should buy that form Roger or other vender, but shipping it to Taiwan...... too expensive.
Old 08-15-2011 | 03:28 PM
LEADASS's Avatar
LEADASS
My x pipe is two pipes that meet in the middle, there's a hole or junction between the two and then they leave as two separate tubes.
Old 08-15-2011 | 09:46 PM
vinyl_tien's Avatar
vinyl_tien
Hi LEADASS
Thanks for your input, Does junction diameter size is equal to original two pipes diameter size? or Larger?
Old 08-15-2011 | 09:57 PM
SMTCapeCod's Avatar
SMTCapeCod
Default x pipe
you can use either an 'x' or a 'y' depending on the rest of the system.
X for duals, Y for single.
The union of the two pipes forms an oblong gap or pass through. Here is one example of a boilerplate design, many are available:
http://www.summitracing.com/parts/SUM-643125/
or
http://www.burnsstainless.com/crossoversmain.aspx
Old 08-16-2011 | 12:43 AM
vinyl_tien's Avatar
vinyl_tien
Hi SMTCapeCod
Thanks for your input.
