Stabiliser linkage orientation
Received 1,289 Likes
In this picture, is the front of the car is to the right or left?
In the WSM, it says "cranked end at the top and tilted forward" so I guest the front is at the right. Right?
I'm asking this because mine are the other way...
Thank you.
Thank you.
Yes this is the same part as the SM too (and on my car).
My question actualy was is it the crancked end or the entire linkage that was tilted forward?
It looks like it is the entire linkage like it is on my car. Good, I won't have to go there again!
Under the Lift
They are symetrical - same for both sides. Front is the right side in the picture in the first post.
I'm not sure how you can put it on backwards. Upside down maybe, but backwards would not line up with the swaybar end position.
