Aftermarket condenser issues
Electron Wrangler
The more heat you extract from the AC condenser by making it more efficient - the worse it will be - its really simple - you are just adding more heat to the air before the radiator.
In the end its just more heat going into whole system - so the whole system needs to take more heat out.
Unless you have some clever way of getting that heat away from the radiator its all just cumulative.
Alan
Alan
+1. A more efficient condenser will extract more heat faster from the refrigerant when the A/C is on. That extra heat will be pushed/pulled right into the radiator.
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Electron Wrangler
Your R143a pressure issues - likely indicate insufficient condenser airflow when the pressure is high - since you are presumably measuring it at idle - you need to at least get your full fan set-up on and perhaps model the hood closed - cover over rad area...
You need to ensure all your fans stay on all the time when the AC is on - as is the case with the stock set-up. You probably also need a low/high refrigerant pressure (clutch drop out) switch as is stock on R134a systems or you can shred your compressor belt if the system overpressures - else you can blow things up this way - the high pressure switch stock is set to go off at 32 bar (calculate the psi on that!).
Anyway do get the AC working well - you need it - but this will only make your cooling issues worse. I think you need to focus on flow - make sure your fans are really adequate and that they guide all the air through with no possible recirculation paths - funnel air to the rad (esp the AC condenser)
If you have no effective rad shrouding - that is a big issue. You may be better off completely sealing off the area of the SC obstruction in order to ensure full fan suction on the rest of the area... 4 small fans attached direct to the rad face is probably not sufficient - funnel them for the full possible area.
How much does the SC block flow through the AC condenser? That may be part of your AC issue - bigger condenser/rad spacing (with perimeter sealing) might help that issue.
Alan
Alan
