928 Forum 1978-1995
Sponsored by: 928 Specialists
Timing belt failure
Old Aug 9, 2011 | 05:12 PM
Hi Ho Silver's Avatar
Hi Ho Silver
Default Timing belt failure
My cam pully broke in two and this also smashed the plastic cover, engine stopped immediately, no bang, was on a roundabout going pretty slowly. Will put up the photos so you can see. Just wonder if any one else has ahd this. Will pull it to bits at the weekend to see exactly what has happened. Mine is a 1982 Euro s 4.7. I bet I have bent the valves.
Old Aug 9, 2011 | 05:13 PM
SeanR's Avatar
SeanR
I'm guessing you have more than a broken cam gear. I bet that camshaft is toast.
Old Aug 9, 2011 | 05:25 PM
Leon Speed's Avatar
Leon Speed
Oh snap.
Old Aug 9, 2011 | 06:05 PM
mark kibort's Avatar
mark kibort
valves probaly are ok, but thats easy to check once you get things apart. the 82 piston pockets are REALLY deep. almost .3". cam lift is only .45" and there is some space between valve seat and piston.
I notice touching of valve to piston pocket with .175 cuts, with .3" valve depression so its safe to say, that tere is no contact with a .350" valve pocket. but you never know!!
Old Aug 9, 2011 | 10:42 PM
Mrmerlin's Avatar
Mrmerlin
Team Owner
I had a US 82 crack the right hand cam gear it took out the left side cam as the snout snapped off
NOTE Left/ right side is seen while sitting in the car looking forward))
the possibility that caused the damage was worn gears and possibly an over torqued ( stretched)RH cam pulley bolt also the timing belt tension was tight the Kempf tool on the older before S4/32Valve versions should be at the low side of the window
Old Aug 9, 2011 | 11:45 PM
James Bailey's Avatar
James Bailey
You might want to edit the title since the T-belt did NOT FAIL......
