928 Forum 1978-1995
Sponsored by: 928 Specialists
Pod removal link?
Old Jul 24, 2011 | 08:59 PM
Erik N's Avatar
Erik N
Been selling Twinkies on Ebay,
have some extra cash right now.
Default Pod removal link?
Will someone please link a good pod removal writeup?
I am still having difficulty getting that center dash illumination bulb screwed in.
Thanks!
Old Jul 24, 2011 | 11:41 PM
77tony's Avatar
77tony
Veteran: Army
https://rennlist.com/forums/928-foru...cs-part-i.html Lucky you, it's by Dwayne. T
Old Jul 24, 2011 | 11:48 PM
Erik N's Avatar
Erik N
Thanks Tony. I frankly did not use the search function, it barely ever works for me.
Old Jul 25, 2011 | 12:09 AM
jpitman2's Avatar
jpitman2
I found the early dash light fittings hard to get back in properly.....hard to get a grip on. In the end I used needle nosed pliers in the crescent shaped holes in the back to get some traction.
jp 83 Euro S AT 53k
Old Jul 25, 2011 | 12:55 AM
Erik N's Avatar
Erik N
I wrapped the plastic fitting with 2-sided tape. That way I could stick it to my R middle fingertip to get it into the hole, and it helped get traction on my fingertips to rotate it. But not enough. I tried messing with the brass contacts, either opening them or closing them... still no luck.
I did manage to lacerate my other hand this time, though.
Old Jul 25, 2011 | 04:06 PM
Erik N's Avatar
Erik N
Fixed that #&%! connector!
The pod area comes apart pretty easily, actually. Should have done it 5 years ago.
Thanks Rennlist!
