928 Forum 1978-1995
Sponsored by: 928 Specialists
Headlight question
Old Jul 22, 2011 | 03:23 PM
GlennD's Avatar
GlennD
Looking at the PIAA website, I see (FAQ) that
Are these legal?
PIAA 9000 Series Bulbs are DOT/SAE compliant and are street legal in all 50 states and Canada.
As well, according to the PIAA website, the second wattage numbers indicate the equivalent power that is produced from these bulbs. For example, from the PIAA website (a different model of bulb but still ) "Rated at 4150K and providing 110 watts of light from only 55 watts" and "Many Xtreme White Plus headlight bulbs feature PIAA Xtra high efficiency design that produces greater light output than their rated power consumption (for example, a bulb that consumes 45/65W of electricity has a light output that is similar to most 95/120W bulbs)."
So, the current draw MAY be okay ... but I would still check.
Interesting bulbs ...
Old Jul 22, 2011 | 10:04 PM
928mac's Avatar
928mac
Originally Posted by Alan
Brad are you sure you even have H5's? if you have an ROW car isn't it equipped with H4's already? - in which case you need 9003 bulbs and my comments wouldn't apply to brighter bulbs in that configuration since the H4 cutoff is so good.
Are you sure you got the right bulbs for your car?
You will need local relays and beefed up direct supplies for these - if not - not only will you likely damage the wiring (difficult to fix) but you won't get anything like full brightness out of them due to voltage dropped across the wiring (if H5's that maybe a good thing...).
Alan
Alan you are right, My car has H4 Bosch lens. So did the guy give me the wrong bulbs, I still have not opened the package
Old Jul 22, 2011 | 11:35 PM
jpitman2's Avatar
jpitman2
If you have 8" Bosch H4 lenses, you just need H4 60/55W Halogen bulbs (which may also be known under a 9xxx number)-
http://www.ozprodrivers.com.au/shop/...&cPath=228_369
Just stay away from the blue stuff, its all hype IMHO.
I dont do much night fast driving and I find these lights quite adequate. Tempted to go bigger (100/80W), but cant be bothered with upgrading relays and wiring to suit.
jp 83 Euro S AT 53k
Old Jul 22, 2011 | 11:40 PM
robot808's Avatar
robot808
Originally Posted by bwmac
Alan you are right
I am trying to remember the last time Alan was wrong...
Old Jul 23, 2011 | 01:40 AM
Alan's Avatar
Alan
Electron Wrangler
H4 bulbs are usually labelled 9003 in the US (NOT 9004 - these are for H5's) return them if you can.
You can upgrade to real 100W/80W bulbs with stock wiring - but no higher - this need not be very expensive...
Local relays will stil get you brighter lights in this config.
I run H4's with 100W/80W - they are fine - even stock H4s are far far superior to the Stock H5s.
Old Jul 23, 2011 | 02:53 AM
macfly4's Avatar
macfly4
these sylvan 9004 ultra bulbs are great! what a huge difference. the light is a cleaner white and has a much better throw than whatever was in there before. should have done this a long time ago. thanks again
Old Jul 23, 2011 | 10:00 PM
928mac's Avatar
928mac
Ya Thanks guys, I returned them and the correct ones are on order.
I ordered the PIAA bulb that are to simulate the brighter white light but only draw 60/55
ILL let you know which bulbs come in, but for now here is the site
http://www.piaa.com/Bulbs/Bulbs-H4.html
Old Jul 23, 2011 | 11:26 PM
Imo000's Avatar
Imo000
Captain Obvious
Super User
Alan
The last Japaneese spec S4 I worked on had RHD H4 lenses. The cutoff was to the left, directly into the oncoming driver's eyes. Putting stronger bulbs in them will make this even worse.
