What is the best way to polish the spider
In typing that title it seems it could be misconstrued to mean something other than what it is.
No Oriental massage parlor action.
I am looking to polish the spider on my 82. I really like the way it dresses up the engine.
I was looking for suggestions on the proper technique.
Remember seeing someone used a brass wire wheel if I remember correctly.
Any suggestions or tips would be greatly appreciated.
Thanks Thom
Thanks Thom
imo this has the best result, not too shiny, not dull, smooth as can be, a unique finish that does not need to be redone. The way it should have come from the factory.
large 3M wheel on a professional buffer
excuse the marks on the plenum, was a cold day and just testing new camera, those marks were from the drooping hood insulation that kinda stuck.
![](https://rennlist.com/forums/attachments/928-forum/472302d1283723435-which-would-you-buy-88-5-speed-or-93-gts-wow-intake928s2.jpg)
Rennlist Sponsor
Look for an electropolishing company near by. Easy cheap, non damaging and long lasting results.
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
![](http://www.928gt.com/images/928Specialists-COVER3-928GTcom.png)
I used on of those little bench mount belt sanders that also have a disc sander. Cleaned all rhe cast seams and marks off the runners and smoothed the top of the spider. I finished with Duplicolor ceramic silver and ceramic clearcoat.
Rennlist Sponsor
Mr Wiki can get you up to speed on this decades old common metal processing.... http://en.wikipedia.org/wiki/Electropolishing
"Electropolishing, also known as electrochemical polishing or electrolytic polishing (especially in the metallography field), is an electrochemical process that removes material from a metallic workpiece. It is used to polish, passivate, and deburr metal parts. It is often described as the reverse of electroplating. It may be used in lieu of abrasive fine polishing in microstructural preparation.[1]"
OH, works great on almost all metals from Aluminum to Stainless Steel...and even 928 Exhaust Products... :-)
Before...
![](https://lh4.googleusercontent.com/-El0A1e9SMUw/TdU2Jy_fCJI/AAAAAAAABJc/DjNCEXB4eaA/Crossovers%252520.JPG)
After...
Before...
After...
![](https://lh4.googleusercontent.com/-l_mCoKYu2wo/TdU2KKwSc7I/AAAAAAAABJg/gA8d1us2Wro/s640/CIMG0876a.jpg)
Shameful Thread Killer
They are called belt file sanders. Not very expensive unless you go Ryobi or Dewalt. Looks like a angle die grinder with a belt sander sticking out. Goes in small spots. Start with 120 grit, and just work your way up to 800. After that, go by hand to 1500, then a polish wheel.
It takes several hours to do the plenum, but the tubes will go much faster.
here: http://www.harborfreight.com/air-belt-sander-97055.html
Thanks all for that had no clue,strange to as i worked on heat treat machinery and controls most of my life. that includes vac dep machines and many others. really notice things around me. oh just for info saw a brown 928 near our summer placce in maine,most stop and find out more.Ray
