Extrude Honing
Anyone in the 928 crowd here have any experience extrude honing engine parts?
911 guys are hit and miss, from the research I've done so far.
Looking into having a 16V Intake manifold done, no pricing yet, still waiting on emails...
Man of many SIGs
There are many threads about this from the past. The general concensus is that it is slightly beneficial but not nearly as much as just using a Euro intake to begin with.
It SHOULD be beneficial, but the 16V pipes are such that their limiting factor seems to be tier overall shape and thier ID
Extruding works better on more compromised inner shapes, ridges, sharp interuptions, etc.
Its also quite expensive.
The place I've asked has told me I'd need to speak directly to Extrude-Hone for a quote. But from what I've read elsewhere, I'm guessing in the $600+ area.
Guess I'll start looking for Euro intake stuff...
Rennlist Sponsor
LINK > http://www.928gt.com/928clearance.htm
![](http://www.928gt.com/images/product/large/1680.jpg)
![](http://www.928gt.com/images/product/large/40654.jpg)
David Roberts
2010 Jaguar XKR Coupe - 510HP Stock - Liquid Silver Metallic
928 Owners Club Co-Founder
Rennlist 928 Forum Main Sponsor
www.928gt.com
928 Specialists on Facebook - 928Specialists
Sharks in the Mountains on Facebook - 928SITM
David Roberts
www.928gt.com
![](http://www.928gt.com/images/928Specialists-COVER3-928GTcom.png)
Saw that, but what's the deal with that mating up to the '84 throttle body? Isn't a euro TB bigger as well? Would seem counter-productive to put a larger intake after the non-matching TB. Then again it has to pull everything through that foolish flappy vane meter....
Part of the honing cost is making plates which will bolt to the flanges or ports. I also believe that they manually grid on the items as far in as they can reach or you can see. Then they pump the abrasive mud to polish out the grinding marks and POSSIBLY open up the areas that you can not see......The also need to be careful not to get it too thin or apply too much pressure in the process or the parts are junk.
Originally Posted by Bonehead Performance
Extrude Hone Pricing
Prices are for Level 1 processing.
Level I PROCESSING
Includes a thorough processing and inspection of your part to provide a linear surface finish to maximize airflow.
LEVEL II PROCESSING*
Includes hand-blending to specific gasket size prior to Level I processing. Automotive heads, intakes & exhaust manifolds only.
*Level 2 processing add $90 for intakes, heads & exhaust manifolds.
Level I PROCESSING
I would have portmatched to my specific gasket size then have had the intake extruded, but the cost right now I'm thinking isn't worth the $.
Rennlist Sponsor
Yes Euro TB is slightly bigger.
Don't forget that the 8 runners are also a larger diameter, which is where most of the gain is, which is why most people Extrude Hone them to start with :-)
In case you are interested, I also have the matching "polished" used fuel rails and also the metal fuel lines and injector retainers, all of those are basicaly new(still have the Made in Germany stickers on them) and will include any or all of those items for a little extra. Basically everythin in the "installed photo" is up for grabs.
Also have "Like New" (not rebuilt) LH Euro S injectors too (not compatible with L-Jet)...heck come to think of it , I think I have almost everything here to convert your L-Jet to Euro LH...then you can Sharktune it :-)
The photo below gives you an idea of the two of the intake runners used on the 928. The one on the left is the S2 intake, note the near 180 degree bend and the restriction near the injector. The S runner is much better with no restriction and only a 90 degree bend. The 90 bend is still far from perfect, the intake that I made below is better again. Much more gentle curves which are better for less restriction.
![](http://i931.photobucket.com/albums/ad152/928S_photos/928intake_runner_conversion.jpg)
![](http://i931.photobucket.com/albums/ad152/928S_photos/928CustomIntakePassengerSide.jpg)
I don't think extrude honing is needed, I used a die grinder and a ball hone which did a perfectly good job. It also wont make much difference what you do when you use an intake with such a big bend in them.
