928 Forum 1978-1995
Sponsored by: 928 Specialists
'85 Mystery Wire
Old Jul 11, 2011 | 01:03 PM
rifitz's Avatar
rifitz
Default '85 Mystery Wire
Hi folks-- first post-- I'm resurrecting an '85 that had a bad cylinder-- cleaning up years of "work" by others, with a fair number of parts from Roger, (who is great!)- in in buttoning it up the front of the motor I have a mystery lead (original) which is a male spade connector in a square plastic surround coming out of the bundle near right side (cyl 1) water bridge. The other clue is a new wire strung to the A/C compressor clutch all the way back through the firewall, which I suspect means that someone jerry-rigged the A/C to work-- I'll diagnose that shortly-- wiring diagram shows a lead to pin 9 on the 14 pin connector, but also a connection to the idle control valve...??
The compressor has one lead to the clutch, which should be the power, but also another with a ring terminal attached to the screw retaining the power lead. Before the electrical tape fell off, it looks like both of those leads may have been connected to this new wire back through the firewall, but that doesn't make sense since that would have power going to the compressor body, in addition to the clutch..
any insight is appreciated-- thx
Old Jul 11, 2011 | 01:08 PM
WallyP's Avatar
WallyP
Rennlist Site Sponsor
If your mystery wire is black, it does sound like it is the compressor clutch power.
The clutch has two leads - power and ground. The ground lead is usually terminated in a ring terminal attached to the body of the compressor or to a fastener on the mounting brackets.
Old Jul 11, 2011 | 01:13 PM
PorKen's Avatar
PorKen
Inventor
You might also run across a single mystery wire by the jump post.
It's for triggering the electric fan if you had the towing option (M208) w/automatic (M249).
Old Jul 12, 2011 | 10:43 AM
rifitz's Avatar
rifitz
The wire is black-- so I'll go with that-- thanks a bunch
Wally--you have some great stuff on your site, things I definitely want as I move through this project--
