928 Forum 1978-1995
Sponsored by: 928 Specialists
5 spd front shift ball cup bushing replacement - Update - problem found
Old 07-04-2011, 01:27 PM
jwillman
jwillman's Avatar
Default 5 spd front shift ball cup bushing replacement - Update - problem found
My forward shift ball cup bushing has disintegrated. I had some tie wraps around the rod to hols in place.
I had to grind off the bolts holding on the heat shield but finally got it off.
I can't see a way to get the ball cup clear of the ball. It does not move up far enough to clear the ball before hitting the top of the tunnel. How would it ever pop off?
Do you have to rotate the adjustable end to rotate the cup off the ball/ Mine is very rusted and I am concerned about screwing it up wprse than just having a missing bushing!
Old 07-04-2011, 02:30 PM
Mike Frye
Craic Head
Mike Frye's Avatar
You should have enough room to pop it off. It's tight, but there should be room.
Can you post a pic or measure the distance to show what you've got to work with?
Old 07-04-2011, 03:35 PM
jwillman
jwillman's Avatar
Unfortunately I can't get a good shot, working on jacks.
Looks like the top of the socket hits the tunnel with an 1/8inch of the ball still to clear.
Old 07-04-2011, 03:54 PM
SQLGuy
SQLGuy's Avatar
Sounds strange. Any reason why, maybe, the motor mounts would be too high?
On mine there was definitely room to pop it off and on. I do think I had to twist it a bit to the side to get it off, though.
FWIW, on mine, I used a torch to melt the old insert and make it easier to pull out of the housing with a seal puller while the cup was still on the shaft.
Old 07-04-2011, 04:05 PM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,802 Likes on 1,367 Posts
The ball cup needs to move rearward, then the whole release arm rotates clockwise (IIRC) into the opening of the upper bellhousing, giving you enough room to pull the old insert out and pop the new one onto the ball.
Did you shim the pressure plate? You need three bent nails in a 'U' shape, then with the car up on jackstands, you pull the lower bellhousing cover (after pulling the clutch slave, sway bar, and starter, ugh). Then using a bigass pry bar lever the lower half of the the release arm (still on what's left of the ball, btw) rearward and shim the PP. Then rotate the engine 120 degrees (clockwise only ) and repeat till all three shims are in. This will give enough slack on the release arm that you can get it off the ball. Pic shows where the shims go.
Old 07-04-2011, 04:09 PM
James Bailey
James Bailey's Avatar
Rob he is working on the shifter linkage and not the clutch at this time...but great photo
Old 07-04-2011, 04:15 PM
Rob Edwards
Archive Gatekeeper
Man, I am losing it. Carry on....
Old 07-04-2011, 05:09 PM
IcemanG17
IcemanG17's Avatar
the forward shifter cup is a PITA.....it can be done, but the really hard part is "snapping" the new one on the ball.....a couple well placed LARGE hose clamps can do it.....
Old 07-04-2011, 05:34 PM
jwillman
jwillman's Avatar
I gave up and decided to put a steel band hose clamp on to keep the socketr on the ball till I figured out how to proceed.
Put the heat shield back on with new hardware and dropped the car off the jacks.
Shifter has always been a bit vague but I could not get it in to reverse. I had to pullshift boot to get enough lateral travel to hit reverse. I now have 3+ inches of lateral travel when in gear and finding the gears is a nightmare.
All I did was add the clamp in place of zip ties. Now what? Looks like I need to be reworking the entire shift linkkage front and back.
Old 07-04-2011, 05:41 PM
jwillman
jwillman's Avatar
I have never touched the motor mounts. This is a 79 so mounts are different than later cars. If anything I would expect them to be compressed from age.
Old 07-04-2011, 05:55 PM
James Bailey
Most likely some of the plastic buts fell out of the socket and has more play than before... but yes time to do it all and see how tight it really can be.
Old 07-04-2011, 05:57 PM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,577 Likes on 1,451 Posts
from the info provided it sounds like the rear shift coupler has also failed or its loose enough to have readjusted itself to be out of position.
it might be worth a look,
Note the front shifter cup is for front to back orientation,
the rear coupler is for left to right if you have 3 inches then possibly one of the rear bushings has fallen out or the 13mm lock bolt that clamps the coupler to the shaft isnt tight enough and thus the coupler has moved inside the rear shift rod. .
Reference the WSM for proper shifter orientation.
Of course you could install Colins new shifter and remove the front rod complete
Roger sells them
Old 07-04-2011, 06:03 PM
Mike Frye
Craic Head
Mike Frye's Avatar
Yup, you're in for both of those sets of bushings/couplers. I would also recommend the release arm ball cup as well.
They're all a major PITA but in the grand scheme of things there are very few ways to really improve the way the car operates that would cost less than these three parts.
Old 07-04-2011, 06:55 PM
Jadz928
Jadz928's Avatar
Mike,
The release arm is a whole 'nother ball of wax on the '78-79's as they use a metal/metal ball and cup.
And the ball is smaller. IIRC, a new style assy is recommended per SB and requires a little surgery.
I'm a little vague on this because I have never done it. Strangely, my #6 had it done, which I was happy to see.
Old 07-04-2011, 07:00 PM
jwillman
jwillman's Avatar
The release arm bushing was changed last year when trying to sort out my clutch issues. One less thing to do
Quick Reply: 5 spd front shift ball cup bushing replacement - Update - problem found
