928 Forum 1978-1995
Sponsored by: 928 Specialists
DD Clutch problem
Old 07-06-2011 | 03:42 PM
blown 87's Avatar
blown 87
Rest in Peace
If you have a new master cylinder it will have to be cut, and a coil or two cut off the spring.
Also be aware that the guide tube is a different length on a DD and a SD clutch.
On your bellhousing, some thing had to come loose for it to do that.
Originally Posted by vinyl_tien
Thanks Mrmerlin
1.I have new release arm bushing.
2.I bought new master and slave cylinder from 928 internation.
Question
I use 85 row parts for convert, I refresh all the clutch parts.
My question is
1. Should I cut shorter of master cylinder piston? 4.5MM, right?
2. Shorter the spring, you mean short this (928 423 357 04) spring parts?
Quick Reply: DD Clutch problem
