Duc's Hybrid build
for the next few days im visiting fam down in Tucson but when i get home its cleaning time! i got the kiddie pool for the engine and lots of mineral spirits and brushes. question. im going to rebuild the oil pump and i am going to take the "pressure springs" out and clean that area up. what should i lube the pressure regulating springs with? im thinking assembly lube...
today i made great progress on cleaning the block. i used a kiddy pool with some solvent and a brush worked well. i also marked and started to remove pistons from the rods for cleaning before i send them to get fly cut for the euro heads. i can only soak 2 in the carb dip can at once, so it will be a few days. some of the rings came off, but most are stuck in the pistons.... :-(
Berrymans for the pistons.
yup, chem-dip. thats what im using. works well. the new stuff is not as powerful as the old light green colored berrymans or yester-year... but the new stuff works well.
I needed 4 days each piston to get them spotless.
Its steel. Its fine.
almost got all the pistons cleaned for shipping to get fly cut. wow, some had so much carbon crap on them, i would not be surprised if the compression ratio was higher...
so i got the pistons all cleaned. one of them i kinda buggered up the top ring area by prying out a broken ring.... hummm. should be ok. im thinking i might send my second set of pistons to get fly cut as well, just in case.
so about this skirt coating....... what is it and who does it? i take it it is a friction reduction coating?
The coating on 928 pistons is iron from memory (ferrostan rings a bell?).
Its needed to stop the pistons galling on the cylinder walls - best thing to do is leave it well alone.. to not scrub with anything other than a reasonably soft nylon brush, using a non-caustic cleaner.
