View Poll Results: Carpet Options
Sliverknit - keep it stock
22
48.89%
German Velour - slightly more plush
10
22.22%
Other - More Modern Materials
13
28.89%
Voters: 45. You may not vote on this poll
Interior Carpet Poll Sliverknit, German Velour, Other?
Not the sharpest tool in the shed
I am thinking about carpet options for my cars. I have the stock Sliverknit but I don't like the way it has faded and looks slightly matted. So, I am asking for advice over other carpet materials or recommendations as to why I should remain with Sliverknit.
Upholsterers prefer Sliverknit because it is lighter/thinner and therefore easier to form around curves and tight places.
Please vote your preference and post comments relative to your experiences.
Thanks so much,
Dan
Thanks so much,
Dan
Dan, since you are changing it out and willing to go non-factory anyway, I say put in the best stuff you can find! The cars (both of them) are SO AMAZING that anything less would be criminal!
I just did the velour from Robert Budd... DEFINITELY DO THE VELOUR!
Keep in mind, it is a good HARD weekend project to remove and install, realistacly two weekends.
Velour is NOT any harder to install than silverknit. Glad to provide tips and tricks either way..
What passes for sliverknit today does not come close to the original stuff in my euro. Not as tall or dense or soft.
I was searching for the best stuff you could possibly get and found it in England, if i remember right, stuff that goes in Rolls I think (at least according to their write-up). Was a few years back. But that is stuff I will use when I get around to it. Why not get the best.
here - http://www.heritagetrim.com/m_aboutmaterials.htm
maybe even this stuff - http://www.williammarstonltd.co.uk/i...WOOL-NYLON.png
You would have to compare samples in your hand. I always check the carpet when I go into new car dealers, not too impressed with most.
Cowboy,
First off, I can't believe you are consider anything other than full bore badd arss carpet on either one of your 928s!!
With that being said, I'm sure attached carpet comes in a color to suit you if orange doesnt!!
Screw the carpet.. I want my car's exterior done in that "Wimbledon Centre Court" look/feel!
If the color I wanted was available in a domestic fiber.... I would pick that one. My shoes won't know the difference, but my wallet will.
Robert sent me samples of basic replacement material and Sliverknit to compare. The Sliverknit is my choice. It is thicker and looks like it will be more of a challenge to install but just looks richer and will have better sound deadening. It is just a little lighter weight than the exist stock Sliverknit.
Archive Gatekeeper
The answer is whatever carpet supplier can provide a carpet set that matches Turquoise metallic.
You would have to get samples of all in the same color and compare. Your feet won't know the difference, but you will. Life is short and filled with hassle's. Driving these is an escape, pure enjoyment, why not if you can swing it, make it the best possible experience, the carpet, the leather, the steering wheel, and an after-market exhaust. Get the most out of it.
