fuel tank drain plug?
i'm going to change my fuel filter and was thinking of draining the tank on my 87 s4.car sat for a long time and recently started sputtering and stalling when it gets below 1/4 tank.is there a plug?
Yes, the fuel pump and filter is under the tank and it pulls the fuel from the bottom. On the top of the 928 tank is the fuel level sender assembly.
Dan
'91 928GT S/C
475hp/460lb.ft
Dan
'91 928GT S/C
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
Team Owner
wrap a few strips of cloth around your wrists this will keep any errant fuel from running down to your armpits
Or.
I siphon from the top to avoid wearing/spilling any, and once you "hit bottom" while it looks as if there's still more to go in the tank, nothing comes out when you remove the tank fitting from the bottom (with the rear of the car slightly elevated).
