928 Forum 1978-1995
Sponsored by: 928 Specialists
Engine swap problem.....
Old Jun 22, 2011 | 12:31 AM
  #31
namasgt's Avatar
namasgt
I would at the minimum change the head gaskets before putting it in. If the coolant was completely drained and the engine sat dry for 8 years, it could have caused the soft sealing material on the head gasket to shrink.
Old Jun 22, 2011 | 04:18 AM
  #32
danglerb's Avatar
danglerb
Euro hybrid and a stock early 32v are going to be close to the same HP, more low end torque maybe on the 32v. Best choice for a boosted motor would depend on who's system you use, which motor that vendor has gotten to work best.
Old Jun 22, 2011 | 10:43 AM
  #33
Ducman82's Avatar
Ducman82
Veteran: Air Force
i like DR's twins screw. its different! im going to check with DR today and see what he recommends.
Old Jul 14, 2011 | 07:29 PM
  #34
Ducman82's Avatar
Ducman82
Veteran: Air Force
so, it turns out i got that 32v , the guy did not bat and eye at my offer, .... i prob should have started lower.... :-) so now i will have a spare motor chilling. already started my hybrid build. :-) pistons are sent to be cut, and euro heads are being worked on. weeeee!
ill post some more pictures when i get that motor home.
Old Jul 14, 2011 | 08:03 PM
  #35
BC's Avatar
BC
Cool.
Old Jul 14, 2011 | 08:11 PM
  #36
Erik N's Avatar
Erik N
Been selling Twinkies on Ebay,
have some extra cash right now.
Stick with your original plan. Then you will have a running car.
Sell the 32V here on Rlist.
