Cam pulley bolt torque
1990 928 S4 what is the cam pulley bolt torqued down to?
Do you just torque it down or do you need to hold the washer bolt and them torque the bolt?
Under the Lift
+1 to what Greg said. ALSO...although holding the large washer is intended to keep the cam and gear stationary, the cam and/or gear often will move a few degrees or more as you apply the proper torque to the bolt. You really need the PorKen tool to check the cam timing AFTER you tighten the nut, unless you have the cam covers off and can check the cam timing per the shop manual or other technique.
BTW, the torque value is 47 ft-lb.
Rest in Peace
yes, I have the WMS, but didn't have time to look it up. Wanted to know if somebody had it handy. Yes I have the Porken 32Vr that is what I used to check timing and now want to torque them down.
Rest in Peace
No, you are looking up the wrong thing if you went 217 FT, which is what that is, then sorry but you deserved to break a bolt or a cam if you try to put that much torque on a bolt that small.
If you are in a hurry do not work on a 928, it will not end well I promise you that.
Rest in Peace
That is for the crank bolt, an it plainly says that it is for a 18x1.5 pitch bolt, which is a far cry from the 10x1.5 bolt that you are talking about.
Always look at the bolt size and do a mental comparison to what you are going to tighten.
Nice consolidated torque figures are in Tech Spec books. Just watch the units.
Find a post by Andrew (AO), click on the links in his signature line.
Under the Lift
My point above is that you need to use the Porken tool again after you finish torquing.
