surgery on cooling fans
decided before i bought new cooling fans i would try to take them apart and clean them.wasn't too bad of a procedure.found alot of black dust in them and some rust on the rotors as well.cleaned them out and reassembled them and tested on the bench.while they are out i'm going to change belts.
Archive Gatekeeper
How do the bearings sound on the post-clean fans? I put 2 new fans into the GTS before heading to SITP, 'cause the old ones sounded like crap and I've just run out of time for projects lately.
Here are audio files of old and new- not much difference when running but listen with headphones to the tail end of each file and you can hear the bearing grind a bit.
Old:
https://webfiles.uci.edu/redwards/pu...%204-19-11.mp3
New:
There's a great writeup on here about rebuilding fan motors, by 928Myles:
https://rennlist.com/forums/928-foru...iator-fan.html
Old:
New:
It's an easy job to change the bearings when the fans are apart. At that point you can't tell them from new.
I posted, not long ago, what bearings are needed for a cooling fan rehab. As a bonus, their cheap, too!
'84 Euro 5 spd.
'84 Euro 5 spd.
