New product - SharkTuner Alpha
#76
- I think that ISVs and other such closed loop idle control systems run closed loop based on the deviation of RPM from the set point. They don't target the MAF signal. The MAF signal usually only influences the amount of fueling and timing of spark (and if it gets those wrong the car idles poorly or stalls)....
- When big cams are used, individual throttle bodies usually idle better than plenum manifolds irrespective of how the engine is controlled. I believe (but do not know) that this is because the almost completely closed throttle plate near the port reflects the pressure wave back to the cylinder in a certain way. Alpha-N, MAP, MAF, anything will all get a better idle with hot cams from ITBs than from a single plenum with a single throttle body.
The whole point of the Alpha system is that getting rid of the MAF allows intake arrangements that don't lend themselves to single-point flow measurement with a MAF, such as ITB's. Sure, ITB's with a common plenum can be measured upstream of the plenum with a MAF, but that's not ideal and not always convenient.
And so does Alpha, we've driven some 25K over the last 18 months without a MAF. The point is that you don't need a MAF, and there may be more design choices without. Heck, even putting a proper bell-mouth where the MAF is would be a great help.
Cheers,
#77
Tuomo,
MAFs have benefits and pitfalls too.
One benefit is that any mods can be bolted on to increase power and the additional air is easily accounted for (X-pipe).
A serious downfall (for me), is that the engines rpm/sec is much different in 1st to 5th gear. Because of this the rate of airflow over the hotwire changes from 5th to 1st. So if you tune for 5th, 1st will likely be overly rich. This has been very apparent in a number of cars I've worked on. Another downfall is that if the MAF becomes disconnected from the intake, or you get a vacuum leak your vehicle goes totally lean, or pig rich (if boosted) making the vehicle unusable, or highly prone to failure.
My preference is to standalone MAP based systems which only measure manifold pressure as if you get a vacuum leak, your idle goes up, but your fueling remains the same. Or if a boost pipe pops off, the engine will still run enough to get you off the road and to safety.
#78
This is true, not because of any "reflection" but simply because you are isolating the cylinders from each other. None of the resonances (intake or exhaust) work in slow-motion. What happens with a single throttle is that the plenum is under some vacuum, the exhaust is at atmospheric or higher, and if you open both valves at low RPM's then the exhaust gas flows backwards and fills the plenum. Does this literally cause reverse flow in the MAF? I don't know, that's one theory but not relevant here I think.
I agree the motivation for using Alpha-N in some plumbing situations.
I think it's extremely unlikely that a single MAF attached to a single plenum of a V8 will see literal reversal.
I think that higher order resonances work at lower RPMs as well.
Yes, I agree that one of the reasons for the lack of low RPM oomph of some "manly" cam engines with single-throttle plenums and very short runners is that low RPM reversal sends some inert exhaust gas to the plenum which is then sucked in by another cylinder. If you use a MAF to feed the plenum, however, the mixture will still be correct and exhaust gas is simply recirculated which shouldn't hurt the idle. It's just inert gas there in the mix, much like nitrogen in air. And the same thing happens with ITBs if you floor the pedal at low rpm.
Another problem with big cam, short runner, single plenum, port fuel injected manifolds is that, at low RPMs, the reversal from the head can kick out an unpredictable amount of fuel to the plenum and the next cylinder. ITB systems that have the injector between the head and the throttle plate fix this problem. There's a design tradeoff there, however. The peak power grows with the distance of the injector from the port up to about (impractical) three feet. That's why some race engines have the injectors way upstream pointing to the runner, resulting at a higher peak power but worse idle. I recall seeing a sports bike (Yamaha?) with double injectors, one at the port for low RPM and one pointing to the bell mouth for high RPM.
So who knows why but big cams seem to work better with ITBs. no disagreement there.
Tuomo, MAFs have benefits and pitfalls too. A serious downfall (for me), is that the engines rpm/sec is much different in 1st to 5th gear. Because of this the rate of airflow over the hotwire changes from 5th to 1st. So if you tune for 5th, 1st will likely be overly rich.
#79
One of the most restrictive component on intake system is the MAF. There are numerous testing done around this. This is why I would consider switching to use MAP.
I wonder how many PSIs of boost will be lost in stock 928 intake setup...
http://autospeed.com/cms/title_Elimi...2/article.html
http://forums.mazdaworld.org/147-tec...surements.html
For the Turbo setup, the wery best intake will be the WRC style one. The air flow to turbo in WRC engine is being limited with specific restrictor plate
and therefore the engineers need to find "lost" power from wherever it's possible. There must be a reason to use this kind of plenum...
Check the CFD pictures of those links, look how even is the flow velocity on each intake tube.
http://honda-tech.com/showthread.php?t=3016531
http://forums.hybridz.org/index.php/...anifold+%2Bcfd
This would be the way to go for V8 T or TT as well. Local shop is doing DIY kit. 2 x separate WRC plenums, having separate throttle plates or connected to one larger TP.
http://www.amworks.com/pictures/WRCWEB.jpg
http://www.amworks.com/pictures2/EVOWRC2.jpg
On NA engine, it may not beat ITB's but are wery close...
#80
Inventor
The auto makes it even worse, with the torque converter making a constantly variable gear ratio.
For my own tuning, I have decided that autos can't be used for making a fuel map from scratch.
What's needed is a speedo input to select a map, or a correction factor, for each gear.
Plenty of room for those maps in LH2.3.
If only I had a S4 5-speed to start tuning with/coding on.
#81
For the Turbo setup, the wery best intake will be the WRC style one. The air flow to turbo in WRC engine is being limited with specific restrictor plate and therefore the engineers need to find "lost" power from wherever it's possible. There must be a reason to use this kind of plenum... Check the CFD pictures of those links, look how even is the flow velocity on each intake tube.
The conical feeders to the plenum are a great idea regardless, and two of those should work well on a single plenum system no matter whether there are eight or two throttle plates.
#82
I don't want to hijack the thread, but thanks to those explaining reversion. We got into maybe two or three levels of more complexity and detail on Speed Talk without consensus on exactly what is happening other than flows dynamically change sufficiently to create a mixture that won't fire.
#83
#84
Tuomo,
The accel enrich is a very momentary item. Think of it as an accel pump on a carb. A heavy stab of the throttle and it pumps (do to speak), but a slow roll on the throttle and nothing happens.
I do use steady state (mustang eddy current) dumps for tuning going up and down the ranges. And I use 4th gear tuned ever so slightly to the rich side so that 5th doesn't run out of fuel. 5th gear is too tall for most dynos to touch redline on 5th gear.
A speedo input to pull fuel out at low speeds would be a great idea. Or doing the speed density alpha N tuning as that will remain constant regardless of rpm/sec.
But alas that wouldn't work for boost.
I have my turbo car running VEMS w/ COP now so thankfully not an issue anymore on that car. But it's still a fight on a stock car.....
#85
Here's an explanation of the problem that the acceleration adjustment parameters seek to solve:
The only way in which the gear can matter is load and engine acceleration. I can't think of any other reason why a car that has a correctly tuned base map for steady state operation at all loads would behave differently in different acceleration rates than the acceleration adjustment not working. The likely reason for it not working is that the acceleration adjustment parameters are not set optimally.
Tuomo,
#86
There may be an issue with the acceleration enrichment on the stock 928 LH 2.3. When I set the base value in fuel params to even -64 on ST2, I don't see any change under transient load conditions.
Dan
'91 928GT S/C 475hp/460lb.ft
Dan
#88
I asked John Speake about the digital display's fuel consumption information. I posited that the LH is using injector open times, and knowledge of flow rates (stored in a constant in the computer somewhere) to calculate the instantaneous consumption display.
He advised that this was indeed how it worked, but that the constant is NOT stored in the EPROM, so Sharktuner can't change it. This means that installing bigger injectors results in several of the display's functions become no longer useful.
#89
Here's the current acceleration adjustment documentation:
On the right hand side are adjustments of fuelling when the throttle is opened quickly – transient enrichment. Transient enrichment is necessary to counteract the lean out that occurs in engine when the throttle is opened quickly.
“Base setting” has a default value of 0 and a range of +/-64. Positive values give a larger injector pulse length.
The next four tabs are self explanatory. They scale the enrichment applied to the first four pulses after a transient condition is detected. The default values are the standard Porsche values of 400%, 325% 200% and 100%.
The last tab is “Sustain”. This determines the decay rate of the enhanced pulses to their normal value. The default value is 2, and the adjustment range is 1-10.
Note that these transient enrichment adjustments should be used in conjunction with the “Acceleration enrichment” map. This is explained further in the “Editing acceleration enrichment fuel maps” section on page 28.
The WOT map is used when the wide open throttle switch is closed at approximately 2/3 throttle opening. The injector opening time is calculated using the base fuel map PLUS a value taken from the WOT map for extra mixture enrichment for maximum power. Therefore it is important that the base fuel map is correctly mapped before the WOT map is optimised.
Contrary to popular belief, the base fuel map is used for mapping values at WOT. For this reason, Autotune can remap the base map to a target A/F ratio at WOT. Autotune does NOT adjust the WOT map.
The WOT map is used to add additional fuelling if required, i.e. if a richer mixture is required as some points, or the required A/F ratio cannot be made rich enough within the adjustment range of the base map
As can be observed from the WOT screen, the map is only using rpm as its look up value. The fuelling adjustment possible has a similar total range as the base fuel map, approximately 50% but in this case only positive values from 0 to 255 are applicable. Increasing the values in the map increases injector on time, and hence reduces the Air/fuel ratio (richens mixture). As this implies, you cannot have a weaker mixture at WOT than at the upper load levels in the base fuel map. A value of 0 in the WOT map means that the fuelling is identical in WOT or non WOT conditions at that rpm/load setting.
EDITING THE ACCELERATION ENRICHMENT FUEL MAP
This map is used in conjunction with the transient enrichment values which are available on the RHS of the Parameters screen. The values on the Parameters screen are set when the engine is at normal operating temperature, and after main map adjustments are complete. The acceleration enrichment fuel map then allows adjustment of the transient enrichment versus water temperature, if required.
#90
Accel enrichment is very complex in how Bosch have designed it. On the first big stab of the throttle, you get the enrichment as set by the parameters available with the ST. Imeadiate subsequent stabs at the throttle don't trigger the enrichment. I have observed this on the test jig. There appears to be a complex time/size and rate of load increase algorythm. We have never had the time to investigate nor any pressing need as I haven't had any problems tuning fuel over the rev range.
At present we are unpicking the ISV system design which is also very complicated.....
