Ignition timing question
I have attached the picture and text from the WSM.
Another question is I am about to replace my steering rack due to leaks. I could have sworn dextron type F was what to fill the system with, but the WSM says Dextron II. I am assuming the WSM is right and I just made up Type F for some reason.
Thom
Take a look here:
https://docs.google.com/fileview?id=...MTI0Nzll&hl=en
For the 82 models it's 28ş for Euro cars and 23ş for US cars.
Regards
For your rack replacement and since you'll have the system drained, it's a great time to replace the filter/reservoir assembly. Also a good time to replace at least the two hoses that attach to the reservoir, and reseal the pump if it's leaking at all (inexpensive kit from our suppliers). For sure the copper banjo washers will need to be replaced. Get new tie rod assemblies with your rack unless they have been replaced in the last 50k or so. I can also recommend that you grab a can of spray engine cleaner, and use it to de-slime the rack and crossmember area just before you start your work. Much better than swimming in slime from a leaking rack.
