928 Forum 1978-1995
Sponsored by: 928 Specialists
Running my Car (S3) on E85 (UPDATE - 7/6 PASSED!)
Old 07-01-2011, 12:11 PM
  #61
BC
BC's Avatar
Originally Posted by Hilton
Out of interest, what heat range spark plugs are you using?
Just changed them to NGK BR7ES
Old 07-01-2011, 12:12 PM
  #62
BC
BC's Avatar
Originally Posted by andy-gts
what would happen if you used an air pump and ran air into the exhaust way up stream from test site on the pipe....would this allow co to change to co2....and thereby lower the co level?
andy
The air pump, technically, IS pushing quite a bit of air into the exhaust - as its supposed to, at the newly installed cats. Is that what you mean?
Old 07-01-2011, 12:13 PM
  #63
BC
BC's Avatar
Originally Posted by svpmx83
Have you seen the flexfuel interceptors ?
rather than mucking about with fuel pressures and injector sizes which will mess with atomisation and efficiency. These things are supposed to add to the factory ecu duty cycle to compensate for the fuel change.
I just did an ebay search for "EV1 E85"
http://cgi.ebay.com/ebaymotors/E85-C...item25652f4517
2 required for a v8 at $110 each
or their agent in the US http://ez85.webstorepowered.com/
no affiliation !!
Thanks for the suggestion - if they are non-related to other engine parameters - that is essentially the same thing to raising the fuel pressure in SOME ways - other ways they may actually help. With that sort of cost and larger injectors, I may as well go straight to megasquirt.
Old 07-01-2011, 12:15 PM
  #64
BC
BC's Avatar
Originally Posted by danglerb
I can't see anything good coming from a visit to the smog referee. Some know smog issues really well, but can be capricious in accepting or failing a car.
Tipping on a smog test isn't something I've ever seen. I've heard of outright bribes, but not tip sized ones.
I read their page. I don't see where my situation is listed - they don't just want people randomly making appointments if there is no specific referee-mandated situation like engine swap, etc.
Old 07-01-2011, 03:18 PM
  #65
BC
BC's Avatar
Originally Posted by Bill51sdr
NOT a good idea. The O2 sensor would see this extra air as a "lean" condition and fatten it up even more.
Brendan, perhaps you should go back to stock injectors if you don't already have them in. It could be that higher capacity injectors are still injecting too much fuel at low RPM's even at a minimal pulse width.
The injectors in there are New Stock 24lb blue injectors.
Old 07-02-2011, 10:32 PM
  #66
Imo000
Captain Obvious
Super User
Imo000's Avatar
Originally Posted by BC
I am. But thanks for taking the opportunity for a dig dip**** - I've seen your game before. The fuel is not the issue - as anyone with reading comprehension can see - even with massive overfueling the HC and NO numbers are below average - symbolizing a very clean burning fuel.
CO is the resultant compound that comes from ANYTHING that burns. Wood stove, kerosene engines, diesel, etc. You burn more, you get more of it. I'm doing something wrong here, and part of the issue is that I cannot manipulate the ECU at this time. E85 has been proven to be a very clean burning fuel that has vast opportunities for high-power and high-hp-small-cc engines.
Alcohol burn extremly clean, that's why it hardly has any flame, everyone knows that and you can drop the name calling. You had problems with this car even before the E85 and still stumbles so prehaps fixing that before experimenting with alternative fuels would be a my choice.
Everytime a comment is made against E85, you go off the handle. WTF?
Old 07-03-2011, 06:05 PM
  #67
andy-gts
andy-gts's Avatar
bc
yes , I thought that the car was an airpump delete for some reason....
Old 07-04-2011, 12:42 AM
  #68
BC
BC's Avatar
bc
Right now, and even before the cats, it had an airpump. As far as I know it is pushing air. Thanks.
Old 07-07-2011, 12:56 AM
  #69
BC
BC's Avatar
It passed! Done and done. I think several things were learned here, but I believe that one, unfortunately, is that the previous smog guy was.... Playing me.
I'll
Scan this test asap and you can see the CO that went to 0.0.
A small decrease in fuel pressure settings causes a cat-installed car to go from 1.6% CO to 0.0%? Not so much.
I'll try and scan it tonight.
It seems like the situation is that I could have passed with no cat if the visual was not an issue and I turned down the FP a bit more.
Old 07-07-2011, 12:59 AM
  #70
neilh
neilh's Avatar
I'll
Congrats Brendan, who did you use?
Old 07-07-2011, 02:05 AM
  #71
BC
BC's Avatar
I called the place you suggested, but they did not recognize the name of the guy Neil. So I was in "Korea/Vietnam" town (Kearny) today and went to one of the well-rates smog places there. It was in, out, and passed in 20 minutes.
Old 07-07-2011, 02:27 PM
  #72
BC
BC's Avatar
This is the newest scan, and its a pass! As you can see the previous high CO are now non-existent. I do not believe such a small change in fuel pressure could have made such a large difference and I do believe that I have been played a bit by the previous guy. I don't know why or how. It could have been me getting somewhat upset at him for his foolish rigidness for the air-box top.
Old 07-07-2011, 04:26 PM
  #73
Richter12x2
Richter12x2's Avatar
This is simply a "Does it work in a 928 longer term" thread.
With that in mind, I'd be more interested in the effects on the alloy of the block than the fuel lines necessarily. Especially since the Nikasil alloys seem to be very particular anyway. Less gas mileage and replacing fuel lines, I can get over. If my block cracks in another 30,000 miles because there's less lubrication from fuel due to the alcohol content, that's a lot more expensive.
Old 07-07-2011, 05:01 PM
  #74
BC
BC's Avatar
I'm not exactly clear on what you are particularly referring to when you are talking about the cracking of a block. Are you speaking of the reduced lubricity of the fuel? There is some reduction in the "slipperiness" off the fuel in terms of sliding metals like the fuel pump internals, and this is obviously something to watch closely. The 15% actual gasoline usually takes any reduction and makes it irrelevant. At the engine side of the equation there is no such concern as the normal
Lubrication system easily takes care of this. "fuel in the oil"
Is a concern for everyone, and technically speaking, it would evaporate from the oil even easier than regular fuel because if it's evaporation pressure.
The engines actually using the fuel propey report cooler engine temps. This would obviously make the oil not sheer and break down as quickly as an engine running hotter.
Old 07-08-2011, 01:18 AM
  #75
sendarius
sendarius's Avatar
Nikasil? In a 928?
What did you do - swap in a flat-6?
I seem to recall this being hashed out many times before. The 928 blocks (like their baby brother 944 blocks) are Reynolds 390 High Silicon Aluminum Alloy, also known as AluSil. There is no Nikasil in the block.
Quick Reply: Running my Car (S3) on E85 (UPDATE - 7/6 PASSED!)
