it is alive IT IS ALIVE!!!!!!!!!!!!!!!!!
well, just fired up the 928 after the WP/TB job.... it fired right up, idled like a champ. I also installed an X pipe..
I have a few questions.
first is about the timing belt light. i installed the porktensioner, so i am no longer using the tensioner warning light. My question is all i have to do is ground the timing light wire to get the light off.... correct?
next is the band clamp for the x pipe. The band calmp has two diameters. the larger is too large to tighten on the x pipe section.
how do i get this to seal the connection.. i am runnning xpipe, no cats at the momnet.
the few square inches of cloth are not even close to taking up the space left after tightening the clamp.
also, i am using the clamps that came with the xpipe
thanks
thanks
Yard, can you post some audio of your new exhaust? Interested in the sound w/o the cats.
Congrats on the fire up.
Yes, ground the tension sensor wiring and it will go away forever.
X-pipe, are you using cats? The 2.5 should clamps at the front of the cats, the 2.25s should be at the rear of the cats.
On Edit.
well****readingcomprehensionsucks.
I've not fitted one w/o cats, what size clamps do you have?
On Edit.
i don't have the box, but it is a "step down" type with two diameters, it seems like the whole thing is one size too big.
as for the sound, it actually seems more quiet than the stock pipe... when i put my foot in it, it seems maybe a tad louder, but overall it seems more quiet... but it does sound different, more raspy i guess....
although i am neither confirming nor denying having pics of the wife working on pipe, she was recently helping with the timing belt adjustment......lol...
lol....
she will not be joining us unfortunately..
she has to work Sat, and cannot get around it..
I am heading out in a few hours.. see you guys there.
Team Owner
Jerry get back in the shop
