waterpump bolt leaking!! ???
Under the Lift
Brian,
Look again, this is a different bolt you are pointing too.
The one that you claim is leaking should not go all the way through. In other words, defective pump.
You can use thread sealant, or silicone to plug that leak....
Here's a pic of the back. It looks like there is a casting mark where the hole is. I wonder if it was really thin and just started to weep. I appears to be quite possible.
Where you say it is leaking, the other side is that dimple.
Under the Lift
OK, maybe all/most of us are a bit confused as to which bolt is leaking. I agree the M8 bolt Brian thinks is leaking is not a bolt that goes through to the gasket surface. Brian, either the pump shaft seal is allowing coolant to squirt in the direction of that bolt or ???
OK, maybe were all/most of us are a bit confused as to which bolt is leaking. I agree the M8 bolt Brian thinks is leaking is not a bolt that goes through to the gasket surface. Brian, either the pump shaft seal is allowing coolant to squirt in the direction of that bolt or ???
So I ordered a new waterpump today.....better safe than sorry!!
